light airbag
Airbag Light
Okay, just had something brought to my attention about the airbag light which would normally be on the dashboard next to where the hazard button is. I'm sure that I used to have a light which lit up and showed something about the airbag being enabled...Vauxhall also said that I should be seeing one...but it's not lit up now and i'm sure it used to be...Does anyone know what I mean and also know if it should or shouldn't be lit up...?
check all fuses i will have a look tomorrow
but if you had a fault it would be on all the time
Ahhh right okay, just thought I remember it always being on when I first got it and now it's always off...but all the photos I have seen online also show it turned off. What is that light actually indicating anyway?
Phew! False alarm mate! Had a read through the owners manual and the light is only supposed to come on for 60 seconds after starting the engine...just tested it and it does indeed come on and then go off after a minute Smile
if it stays on on the speedo then it indicates a fault
Yeah it's not showing on the speedo at all dude so false alarm as I say Smile just got a bit worried and thought it was worth a check on here
always best to check
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,327 2:nd-Feb-2021, 21:12:47
  DPF REGEN LIGHT Starie 113 137,896 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,436 11:th-Feb-2020, 13:01:57
  Rear Light Replacement (Need Advice) A.ROD 2 7,099 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  Help engine light Mspencer 12 16,077 18:th-Mar-2018, 17:17:36
Last Post: Mspencer
  No wiring for the interior boot light marcus01 5 8,536 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Rear fog light bulb ID jl47 0 5,327 15:th-Dec-2017, 15:24:34
Last Post: jl47
  Airbag light always on? Ssss 12 14,085 5:th-Oct-2017, 10:50:28
  Faulty back light Jon3sy 4 7,635 24:th-Aug-2017, 17:04:11
  Astra 1.6 Turbo Engine light P0171 abba34 1 7,094 7:th-Aug-2017, 04:21:09
Last Post: sanj424
