» Members: 12,338
» Latest member: Griff81
» Forum threads: 4,563
» Forum posts: 49,693
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
  Dipped Headlights queries
Posted by: Michael C - 5:th-Dec-2023, 11:29:15 - Forum: Astra-J/GTC - Replies (1)
Struggling to find information online. The dipped headlights for my Astra GTC are terrible(hard to see 3meters infront of the car when driving on dark roads), the full beam is pretty bad too but I'm lead to believe these lights are from the same bulb in this model. Has anybody replaced these bulbs with LED ones and if so could you recommend which bulb you used or even reliable manufacturer, seeing so many different types and a wide range of prices, would like to get good ones without having to trial and error different bulbs. Any information would be much appreciated, thanks!
  1.7 cdti engine judder in 5th and 6th
Posted by: ScottN2211 - 21:st-Oct-2023, 16:27:48 - Forum: Astra-J/GTC Common Problems - No Replies
My 2011 astra j 1.7 cdti is juddering when accelerating from 1500rpm to 2000rpm in 5th and 6th (worse in 6th) no juddering above 2000rpm or when just cruising, only happens when you try and give it some gas. Changed MAF sensor, fuel filter, air filter and suction control valve. Cleaned EGR valve and MAP sensor, also had front wheels balanced, still no joy. Anyone had it before or got any ideas?
  Brake discs and pads
Posted by: harrisk1993 - 19:th-Sep-2023, 21:30:53 - Forum: General Chat - Replies (1)
Hello, I am from the UK and have recently tried to change my pads and discs. But the discs i bought wasn't the right size. I have a astra gtc 1.4L 62 plate
I bought them from GSF, put in my reg on the website and these came up https://www.gsfcarparts.com/za021337 . but like I said they didn't fit.
I have 18 inch wheels. can anybody help me find the right ones please?
much appreciated
Wink Insignia B cluster fitted in Astra J
Posted by: milozic - 19:th-Jul-2023, 17:25:46 - Forum: Retrofit How-to's - No Replies
Hi, something about fitting my Insignia UHS cluster to my Astra J.
.png   download.png (Size: 31.17 KB / Downloads: 141)
[Image: QcpSgTl]
Custom made adapter for steering wheel controls to work, and 3d printed adapters to fit new cluster on original spot.
[Image: hS36I7p]
Some programming, and thats all..
[Image: Dy1WlkK]
[Image: VWz5nBa]
If anyone need any help, text me on WhatsApp (+3867034547)
  A frenchie
Posted by: airainchoc - 23:rd-Jun-2023, 10:42:50 - Forum: Introduction Area - Replies (1)
Hi from France
I'm 37, owner of a 2012 Astra J GTC (2.0 CDTI 165HP)
Nice to be here Smile
  Navi 900 to Android head unit
Posted by: airainchoc - 23:rd-Jun-2023, 10:40:15 - Forum: Electrical - Replies (1)
Hello,
I recently bought an Android head unit for my 2012 Astra J GTC
It's working well appart from one thing, the central control panel of my Navi 900 doesn't work (no light, no buttons) with it.
Is there a way to rewire it to work or something ?
(I'm in France so can't really come for it to be done, have to do it myself)
  TPMS on Astra J GTC
Posted by: milozic - 14:th-May-2023, 18:58:09 - Forum: Retrofit Research - No Replies
Anyone retrofited TPMS on a GTC? I would like to know about partnumbers and connectors, where to buy them?
  Oil Temp and pressure sensor
Posted by: milozic - 4:th-May-2023, 20:18:21 - Forum: Retrofit How-to's - Replies (4)
Hi, i just activate menus on IPC for oil temp and pressure, boost pressure.. anyone have this working on Astra J? It is maybe possible to retrofit some sensors for Oil temp and maybe transsmision oil temp? I think this will be usefull..
  Heated seats wiring
Posted by: Apotetyk - 30:th-Apr-2023, 19:43:43 - Forum: Astra-J/GTC Technical - Replies (2)
Hello.
I have Astra J 2014 Excite.
I bought leather seats from Ebay. I mounted them in the car but I do not have any wiring for lumber support or for seat heating. There is no fuse box in the boot, HVAC control module doesn't have buttons for electric seats as well. Connecting the lumber support seems to be quite easy but the biggest problem wire the seats heating. How can I wire them doing in the cheapest possible way? If it is possible to wire it without the HVAC control module then I could mount different switches somewhere else. I also do not need 3 heating settings, one setting to turn the on for some time is enough. Bascially, I just want to be able to turn the on and off using a switch and that's it. Would it be possible to wire them any other way than they are normally wired?
  Next relay question...
Posted by: phlyer - 17:th-Apr-2023, 15:23:02 - Forum: Electrical - Replies (1)
Right, having located the relay in question I want to check, my next question is how the hell do I get to it?  Mounted atop the passenger fusebox.
Is it a glovebox removal job?
Looking fwd to a reply... more than my previous 4 posts.
