» Members: 12,338
» Latest member: Griff81
» Forum threads: 4,563
» Forum posts: 49,693
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
  coolant pipe part number
Posted by: livo - 8:th-May-2024, 19:42:22 - Forum: Request for information - Replies (1)
Hi, can anyone help me with a part number for the water pipe, It comes off the header tank, it is the lower pipe off the tank, it starts in a small rubber hose then to a metal pipe at the end of the metal  pipe its then rubber again that then connects to something just above the turbo, it is the end rubber pipe that I need that connects just above the turbo to the metal pipe. 1.7cdti 2011 110hp. Thanks
Sad Chirping noise
Posted by: Zaf312 - 4:th-May-2024, 10:48:45 - Forum: Astra-J/GTC Common Problems - Replies (1)
Hi all, I have noticed a high pitch chirping on my astra gtc 1.6 turbo, it only happens when the engine is near normal temperature, when I accelerate it's ok, once I slightly ease off the accelerator just a bit I get this chirping noise, nothing on acceleration though.does not happen whilst idling, pressing clutch pedal or brake does not alter the noise.had belt changed but no difference,the mechanic checked everything and he is baffled.the car runs and performs as it should, there are no oil or water leaks.the noise is so annoying, it's like I have 10 birds in engine
  Opel OPC Seat Wiring Diagrams
Posted by: Blue Dog - 20:th-Mar-2024, 06:04:39 - Forum: Introduction Area - Replies (2)
Quick introduction.  Newbie
Reason for joining your forum.
Attempting to obtain an electrical schematic of the wiring to a 2013 Opel OPC, specifically the two front Sports Seats.
I'm in the process of transplanting a pair of front seats from a wrecked 2013 Opel OPC into a 2013 Ford Falcon FG Turbo Ute.
The Opel seats are equipped with adjustable side bolsters, airbags & possibly lumbar adjustment in the back of the seats.
Both OPC seats are intact & I also have the body side connectors to each seat, with about 6 to 8 inches of loom attached.
Using the OPC body side wiring & connectors I should be able to make a couple of adapter harnesses between the Falcon wiring & the Opel seats.
I'd prefer not to set off the airbags by connecting them incorrectly, hence the request.
If a member could point me in the right direction as to where to obtain the above information concerning the schematics, that'd be great.
  Looking for previous owner
Posted by: iNeoTom - 4:th-Mar-2024, 21:43:20 - Forum: Introduction Area - Replies (4)
Hello All,
I have had my VXR nearly 2 years now and i am wondering if anyone knows the previous owner as the garage i got the car from misplaced all the service history and information that was with the car.
I have now put a private plate on the car but to original plate on the car was ST13 BHD.
Thanks in advance,
Tom
[Image: 4N7UY33.jpeg]
[Image: vJ8vErv.jpeg]
[Image: rKEbzDn.jpeg]
[Image: 7k4QGws.jpeg]
  1.4 non turbo P0171 code
Posted by: Mohammed_Malik - 13:th-Feb-2024, 16:31:53 - Forum: Mechanical - Replies (1)
I have a 2013 Astra 1.4i and the EML light is constantly on, the garage has reset the light but it immediately comes back on and also gives the code P0171.
also when the car starts the fan switches on straight away. I have found some info about a PCV sensor or something? I took the oil cap off and its filled with gunk.
any help would be greatly appreciated.
  steering wheel buttons
Posted by: Misiek1093 - 27:th-Jan-2024, 17:21:38 - Forum: Astra-J/GTC Howto's - Replies (4)
Witam, czy mógłby mi ktoś podpowiedzieć jak zaprogramować przyciski sterowania radiem i tempomatem? mam dostęp do sps
  Reversing camera fitted
Posted by: Astragtc1282 - 24:th-Jan-2024, 17:15:31 - Forum: Members car's progress threads - Replies (2)
Just had a few things installed on the vxr.
Reversing camera, supplied fitted and programmed
also have had cruise control set speed, boost %, hill assist active message and performance test activated in instrument display (video yet to up load)
https://youtube.com/shorts/StTTpOROyt8?s...8fr-NNfE9n
https://www.facebook.com/p/Vauxterations...865682445/
  Carbon sill door protectors
Posted by: Astragtc1282 - 24:th-Jan-2024, 17:11:41 - Forum: Members car's progress threads - Replies (1)
Fitted some new sill protectors as originals all scuffed and scratched
https://www.youtube.com/watch?v=0-886X0YavI
  Old member returns
Posted by: Big Dave2 - 19:th-Jan-2024, 14:16:07 - Forum: Introduction Area - Replies (3)
Been here a long time (registered in Jan 2017) and for unknown reasons the forum went down a couple of years ago and my last post on here was in Sep 2021.
It's only this week that I have found the forum is finally working again. I almost gave up bothering to check occasionally.
Anyway, seems very quiet in here. Hopefully it'll pick up sometime soon once other members realise it's up and running again.
  antenna wires
Posted by: marky32 - 25:th-Dec-2023, 16:00:06 - Forum: Site help - Replies (5)
hi all,
can any one tell witch wire is witch on an astra k antenna are ie white/black/blue
many thanks..........
