Couple of programming questions
Got a hold of a genuine MDI so I want to see which of the following are possible.
Maybe everything is very obvious in SPS but I like to be prepared so I can get it done in one session hopefully.
So here's a first few things I'd like to change:
- no annoying reminder beep for seatbelt
- 5 blinks instead of 3 for turn indicator
- enabling parking sensor info in instrument cluster panel
Are these possible and if so, which module should I be looking at?
programming
New to the forum, I've just upgraded from an Astra  H to Astra J sri.  Wow two different cars. The J drives  hellishly better than the H.
I read  many posts where Tucpal has done  some amazing mods.
This inspired me.  First mod being  Dab Radio,  which I bought and installed. I have tried today using my op com  to enable it but the program box is greyed out.
So is there anyone in the  North East mainly Teesside  area who could enable these and other features  that  can be enabl
navi 500 programming
hi all , just fitted a navi 500 .....i had a cd400 in so needed to change wiring and also fitted the bluetooth module...all working but needs programming as comes up with thieft protection activated....on the radio....does anyone in yorkshire program them ....need help please
Programming high beam assist
Hello,
on the windschield of my astra there is a camera for the lane departure warning, next to it there is a small lense/camera facing forward. it is just beneath the sensor for the light/rain.
I read that this lense/camera is the one for high beam assist. My car does not have this option from the factory. I read that other cars come with the second camera and again high beam assist is not prsent.
My question is: Is it possible to program some module with TECH2 (My friend have it) and enabl
PDC module programming
Hi. I need help. I am trying to retrofit front and rear PDC to my GTC. Everything installed, now i need to programm module. I bought used module, so i need to change or delete old VIN number from module and replace with my VIN number. Any idea how that can be done?
navi950 programming
Hi, Can anyone tell me if I can use normal programming via sps or if I need a vci code to reprogram a navi950 from Mokka controls to Astra controls? & can I add review camera and dab+ to it via normal programming or does this also need a vci code? I was hoping to send it to Rusty for this to be done but he is a busy man and i am wanting to get this done asap. I have a genuine Mdi to do the programming & once done I will no longer need it so can pass it on for a very reasonable cost to anyone who
