i connect this?? how would
How would I connect this??
http://www.gumtree.com/p/cars-vans-motor...to-content
Is it simple to connect this to my stereo or not?? .
yes it is easy to fit but it will not work as an USB that is only the connector part
there is a loom and USB module and programing also needed to complete it
You need the USB kit mate and then it needs to be programmed into the car.
But it doesn't cost £100 new from VX
USB = around £6-10 http://www.autovaux.co.uk/product/133493...using.aspx
AUX = around £6-12 http://www.autovaux.co.uk/product/133187...using.aspx
CIG socket around £6 http://www.autovaux.co.uk/product/135025...using.aspx
Surround = around £12-15 http://www.autovaux.co.uk/product/133065...orage.aspx
Here's a chap who sells the USB port on ebay http://www.ebay.co.uk/itm/VAUXHALL-INSIG...3f0b059a0e
you can cut out for the USB to fit if you wanted.
