advanced assist park
Advanced Park Assist
Has anybody got a 5-door with Advanced park assist?
I have front and rear parking sensors but I want to retrofit Advance park assist.
Looking on EPC there seems to be to different looms for the front sensors but looking at the wiring there is no difference between parking sensors and Advanced park assist.
The back end seems to no change apart from the outer sensors need to be different.
Hi Rusty,
what is the advanced park assist?
BR
Jens
It scans the road and tells you of parking spaces and how much to turn the wheel etc.
Ahhhh ok, thanks!
oh wow sounds good, but id be happy for mine to show what yours does rusty
i presume you got this working rusty??
whats the PDC module code needed for it, and is it just the 2 outer rear sensors that are different?
not even sure it's an option on the meriva, but as i need to source the module and rear sensors and rear bumper loom, i might look for the bits to make it the advanced one if i can.
it dosent use  the side assist / blind spot system does it?  i believe they are sensors in the mirrors... something again i'd like but not sure it's possible on the meriva.
looking on an online parts cat for the meriva b, it lists the following for the park pilot system (factory fitted) what are the codes.. UD5, UD7, POC, AUY etc.
12 32 443
20928121
CONTROL UNIT,PARKING PILOT SYSTEM (FOR FRONT AND REAR PARKING PILOT,POC UD5) (EXC.POC BX6,BREAKPOINT CONTROL MY11.5)
12 32 480
13354532
CONTROL UNIT,PARKING PILOT SYSTEM,FRONT AND REAR (EXC.POC AUY,BREAKPOINT CONTROL MY14.5)
12 47 725
13447860
12 47 184
13354543
CONTROL UNIT,PARKING PILOT SYSTEM,REAR (FOR REAR PARKING PILOT,POC UD7) (EXC.POC AUY,BREAKPOINT CONTROL MY14.5)
12 47 724
13447859
No I haven't still looking for parts not paying £170 for a bit of glass.
UD5 is front and rear sensors UD7 is rear only.
There is an extra sensor on side front and rear. I'm not 100% which one's are different.
Gotya, maybe the meriva can't have advanced park assist... seems a few things it dosent seem to have compared to the astra's
(11:th-Apr-2018, 08:35:38)Rusty2009 Wrote: No I haven't still looking for parts not paying £170 for a bit of glass.
Side sensors is different , you need 4 pcs 13291381  , front and rear 8pcs sensors is the same UD5/UD7.
  Front & Rear Park Pilot Andy_GTC 17 21,325 26:th-Dec-2020, 23:03:44
Last Post: Baich
  Side Blind Spot Assist. Tylerrattv 3 6,203 30:th-Apr-2019, 05:59:39
Last Post: Tylerrattv
  Front camera retrofit for Lane departure and traffic sign assist Rusty2009 124 139,558 2:nd-Feb-2019, 11:54:01
  Programming high beam assist husky 6 16,135 10:th-Sep-2018, 11:02:39
Last Post: husky
  Park pilot connectors.... are these them? gazz292 4 10,283 25:th-Apr-2018, 12:04:26
Last Post: gazz292
husky (4:th-Apr-2026, 13:42:04), dbk2ii (11:th-Jan-2026, 22:20:48)
