7:th-Jul-2014, 08:42:48
*thumbs up*
Tags |
research vxline retrofit bumper |
VXLINE bumper retrofit research
*thumbs up*
7:th-Jul-2014, 21:04:58
why are we waiting,its so frustrating lol
ive just read the whole thread,howz the progress coming along
7:th-Jul-2014, 22:43:14
ha ha its all part of the fun the more you wait the better it will be
it is killing me waiting more than anyone hopefully be done by the end of the month LITTLE UPDATE A few more parts turned up today lower front grill part number 13297796 and the brackets for the inside that join the bumper to the wheel arch liner LH 13372004 RH 13372005 and the fixing lugs for the two above brackets and the inner trim bit i still need to get part number 13297796 6 needed slowly getting there now
14:th-Jul-2014, 19:41:29
E both have new bumper, both primed and ready to get sprayed! Let's see who gets theirs on first, bet it's u!
14:th-Jul-2014, 20:43:48
i have two pieces to get and the paint and they're all not cheap you will beat me
16:th-Jul-2014, 11:51:14
Getting there mate
16:th-Jul-2014, 13:15:51
tucpal Wrote:bumper is booked in for paint next wednesday :cool Mine is getting spray the 1st week in August :(
16:th-Jul-2014, 20:21:21
rusty do you know if the fogs are on the canbus
as they need to be removed if so i will put 50w load resistors on the wires to cancel errors and fool it into thinking there are bulbs there.
16:th-Jul-2014, 20:33:57
They are on the BCM. On the light switch pin 1 (yellow (I think))sends a signal to the BCM to turn on/off front fogs
16:th-Jul-2014, 20:56:08
thats ok the fogs are not on the bulb check
unclipped the fog and no errors at all
26:th-Jul-2014, 07:25:21
*Drum Roll...*
26:th-Jul-2014, 10:05:18
I've been waiting so patiently, damn it lol
26:th-Jul-2014, 10:27:36
its all part of the suspense
my paint sprayer took a few days off the enjoy the sun
30:th-Jul-2014, 22:53:12
update the bumpers painted but i am leaving it there till friday to cure before i bring it home
and fit the new parts and get it on the car just so the paint has a bit more time to harden up also ordered the top grill and bottom bumper trim today so this should all be done and on the car by the end of the weekend as long as vauxhall get the parts in time :cool i have got nearly all the parts now apart from the bottom bumper trim that is coming from Germany and won't turn up till Wednesday so a bit more of a Waite i am afraid but all should be done next weekend and on the car at last i have to paint the the molding today it comes in primer from the factory so that will save a bit of work decided on mat black i don't like the color coded option so here are the part numbers etc griffin badge GM 13264461 molding GM 13375838 grille GM 13339547 backing plate for badge GM 13294635 the last part is here at last lower bumper panel part number 13337864 and i painted the moulding black and wrapped the base plate behind the griffin also So the bumper will be on the car by the weekend i just have to wait till the car comes back from the alloy refurbish as it is booked in tomorrow but nearly there now finally the end is in site
5:th-Aug-2014, 11:03:54
Looking good
8:th-Aug-2014, 15:36:59
GOOD NEWS IT IS DONE AND ON THE CAR,
update and pics to follow later on tonight.
8:th-Aug-2014, 18:31:31
Don't keep us in suspense get them photos uploaded!
8:th-Aug-2014, 19:28:55
tucpal Wrote:GOOD NEWS IT IS DONE AND ON THE CAR, Hurry up lol, wanna see this!!, OK HERE WE GO, How to fit a VXLINE ZENTEC GSI bumper. Here is the VXLINE bumper back from paint and ready for assembly and fitting. The first job is to fit the black trims ether side of the number plate and the two tow eye covers. Next fit the lower grill Then fit the two indicator units. Next fit the upper grill and number plate. turn the bumper over and fit the two brackets and the inside bumper trim Next job remove the old bumper from the car and bring it in to remove and swap the loom etc. bumper removal How To can be found here. http://www.vxoc.org.uk/forum/Thread-How-...r-Facelift Remove the polystyrene crash limiter from the old bumper this is just bonded to the bumper so pull it off and rebond to the new bumper Next remove the loom from the old bumper this is very easy just use long nose pliers to remove the clips and unplug the connectors from the lights and just pull the temp sensor out from the grill As you may have read above the vx line does not have front fogs and my car does have fog lights the fogs are not on the cambus monitoring so they have just been left unplugged on the new bumper and taped up to keep them dry and out the way you will not get any errors by doing this Then remove the bumper bracket support from the old bumper this is just held in place by three screws you will have to remove one fog light unit from the old bumper to get this out. and that is all the parts you need from the old bumper next fit the support bracket and the loom to the new bumper and plug in the indicator connectors and temp sensor. Fit the red tabs to the side of the bumper there are two either side. And that is it you are ready to fit the new VXLINE bumper to the car. All part numbers are listed in the above posts for reference. just a note here 2009 2012 pre facelift VXLINE bumpers fit pre facelift cars with no issues if you were to fit a pre facelift bumper to a facelift 2012 2014 you would need to swap the two side bumper brackets on the car body for the pre facelift ones as the fixings on the side of the pre facelift are different to the facelift the same would apply if you were to fit a face lift VXLINE bumper to a pre facelift the bumper will fit the face lift or pre face lift as long as the side brackets are swapped over the same applies for face lifting a pre face lift standard bumper. over all i am very happy the car looks totally different now just what i wanted. Thanks for all you help everyone cheers.
8:th-Feb-2015, 16:18:10
Turner_SRi Wrote:What you got this full vxline kit and alloys? Mate would you know what those wheels are called?
3:rd-Oct-2015, 18:29:51
Hi Guys,
putting together a list of things I will need to swap to the VXLINE bumper and so far know of the following: Bumper from VXLINE (can i get a bi turbo? not sure if they are the same) Indicators and surrounds Do I need a new grill or will mine swap over? Cheers
17:th-May-2017, 20:50:15
I HAVE A 2012 ASTRA J 1.6 SRI VX LINE AND IM IN NEED OF THE FRONT INDICATORS, TOP AND BOTTOM GRILLES, I ALREADY FOUND A BUMPER
HOWEVER HAVING LOOKED AROUND ALL OVER THE NET I AM UNABLE TI FIND THESE AND VAUXHALL ARE CHARGING WAY TO MUCH FOR THESE PARTS, PLEASE HELP,,, THANKS
21:st-May-2017, 21:55:50
i got lucky and found a used set but the only other option is to buy new
there not cheap as you know
29:th-Oct-2017, 10:38:26
Hi , did you if OPC line front bumper is fit on 5 door astra j 2014 ?
1:st-Oct-2018, 22:36:23
hi can any body help so this is my new bi turbo bumper for my astra but need to track down the missing bits indicator units and lower grill anyone know any links
8:th-Oct-2018, 16:27:25
(1:st-Oct-2018, 22:36:23)Simonc40 Wrote: hi can any body help so this is my new bi turbo bumper for my astra but need to track down the missing bits indicator units and lower grill anyone know any links Your be hard pushed to find them used most likely be looking at new. Astra-J 2.0 CDTI S/S
How To Remove Rear bumper | Rusty2009 | 17 | 35,038 |
7:th-Jan-2019, 18:18:25 Last Post: jamietomlin |
Vxr rear bumper fit to normal gtc | Afus1987 | 3 | 7,405 |
8:th-Apr-2017, 09:24:18 Last Post: Rusty2009 |
How-to remove front bumper from Astra-j (MK6 5 Door Facelift) | Rusty2009 | 31 | 49,664 |
28:th-Dec-2016, 22:58:13 Last Post: tucpal |
Front Bumper lower grille | allymorrison70 | 2 | 7,038 |
12:th-May-2016, 23:01:33 Last Post: allymorrison70 |
How to remove Rear bumper Reflectors | Rusty2009 | 11 | 21,086 |
31:st-Jan-2015, 10:31:31 Last Post: Rusty2009 |
Who read this thread? |
3 User(s) read this thread: |
M.Duman (30:th-May-2023, 00:08:43), exhippykev (20:th-Jun-2023, 21:24:52), Dominattor (23:rd-Oct-2023, 23:29:21) |
