Trade Count:
( 0)
Threads: 1
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: Astra 62 GTC 2.0 CDTI
Sex: Undisclosed
Total Feedback: 0
Abit of a weird one, my DAB was working perfect yesterday, I noticed when I turned my car on earlier that the DAB radio didn't come on, I can click the numbers I have set for favourites, It doesn't do anything.
Sometimes it says DAB not available.
Will I need a whole need radio?
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
Dab is usually a separate module. I'm guessing the radio is seeing the module as it's letting you go into it so possible it's not dab module. It could be an aerial issue. Depending on model some use heated rear window as your aerial with a couple of modules attached , if the rear window is really dirty it could struggle for signal or an aerial module maybe faulty.
I think a diagnostic would be in order just to see. I'm sure others will be on soon that could perhaps throw in a bit more advice. Could even be dab module needs software update.
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Jp, do you know how I can access the modules attached to the rear window?
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Do you know we're the dab aerial is?
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
13:th-Jun-2020, 15:31:01
(This post was last modified: 13:th-Jun-2020, 15:41:57 by Jpbroad1970.)
What car is it you have?
Sent from my Pixel 3 using Tapatalk
Gtc I see
There you go
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
I would agree with John but wouldn't like say 100% without being able to see it.
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
Needs diag, you throw a few bits at it and it still not work. But always worth checking for loose connection.
Trade Count:
( 0)
Threads: 10
Thanks Given: 0
3
Car: Astra J Sport Tourer 1.6auto, Astra J Sport Tourer 1.7cdti 6spd, Astra J 5 door hatch 1.6 5spd
Sex: Male
Total Feedback: 0
My Dab sometimes doesn't work, just as described above, OK on the drive to shops, doesn't work when I return to car and drive home. Just AM and FM as options.
Go out later all ok, this happens in both my J tourers, also Dab reception just goes says Dab not available - I've just put it down to atmospherics etc,
but I guess it could be wiring or similar, but on both my cars? Dunno?
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Can you send the link or send what you googled to bring up that diagram you posted?
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
14:th-Jun-2020, 11:03:17
(This post was last modified: 14:th-Jun-2020, 11:05:37 by Jpbroad1970.)
I have access to parts catalogue, so you need logins to see that.
Made it bigger in case it helps
Items 10 and 11 on yours
https://vauxhall.7zap.com/en/car/
Could try that
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Thanks, I cant see any screws for the rear quarter panel nor the section of the boot lid
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
14:th-Jun-2020, 13:02:19
(This post was last modified: 14:th-Jun-2020, 13:02:54 by Jpbroad1970.)
It's not that detailed really
The aerials are in your side windows
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
pop the kick panel screw under there.
Pop off the top bit (where seat-belt is) screw behind there (not sure there are any more as that was enough to get me access to where I needed to be on the GTC.
