Trade Count:
( 0)
Threads: 2
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: 2011 Vauxhall Astra J 2.0 CDTI SRI
Sex: Male
Total Feedback: 0
Needs Help ASAP
had a problem since the summer where I have speed 3 on my wipers but not speeds 1&2 I have replaced the battery after being told by The AA the battery was knackered but this has not solved the problem
Any help would be greatly appreciated
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
Maybe a silly question but should they be auto wipers or are they the standard ones.
I would be looking at relay , switch wiring , rain sensor if you have one and wiper motor.
Any fault codes present?
NAVI950 , DAB+ & Rear Camera , quick heat, auto lights and rain sensor retrofit
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Hi JP,
They are standard wipers not auto unit checked the relay and no change and obviously changed the battery but another thing is the start stop system won’t work either which is symptomatic of a dud battery but since the change of battery this hasn’t started working either so I am a bit stumped
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
Did you fit an AGM battery for the stop start .
What year is the car?
Did you get any other codes when the AA checked?
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
It’s a 2011 model Astra J 5 Door
The battery is AGM
No other codes present on AA system
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
If I was a gambling man I would start with the switch , then I think it goes to bcm and out to motor. Do you have anything else that isn't working?
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Just the parking sensors but I believe that will be down to me breaking one and it been off the car, when I put it in reverse it just tells me to service parking assist but that’s the only other thing that isn’t working
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
That will be right it will know 1 is missing.
Easiest thing first be look inside bcm check it's got no water damage.
Then if you know someone with another astra try a switch.i would say more than likely a wire issue but it's difficult without seeing it.
Try this link it explains slot
https://workshop-manuals.com/vauxhall/as...operation/
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Thank you for all your help I’ll go away and have a good route around the different things
Trade Count:
( 0)
Threads: 12
Thanks Given: 0
4
Car: Astra J SRI
Sex: Male
Total Feedback: 0
No worries, makes some sense with the reading
Trade Count:
( 4)
Threads: 359
Thanks Received: 8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
I would say switch also, but without running any tests I wouldn't like to say 100%.
As to stop start there are so many requirements for it to work it's a very common thing people saying it doesn't work There is a thread on here & I did put a link into the workshop explaining the Stop/Start system https://www.vxoc.org.uk/forum/Thread-Wha...o-not-work
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Hi guys, just a quick update, wiper stalk has been replaced, also the wiper motor has been replaced with no results I think the only option now is to get BCM reprogrammed at vauxhall
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
are there any codes stored on the BCM
Trade Count:
( 0)
Threads: 2
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Hi rusty I have used a cheap reader and cannot find any going to ring an auto electrician or take it vauxhall for diagnosis
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Yes cheap readers don't tend to pull up any codes.
once you've got a proper read post back here, and we can work from there.
If there are loads of errors logged on the BCM it could point to the BCM being faulty (but that would normally lead to more dash error messages mileage not displaying etc).
Just as a side thought have you checked all the earth points are good?
If you want to save money you can get yourself a nice little op-com which will read the codes.
I always advise buying from here (you can buy from ebay but they won't have any higher version than this guy)
https://www.op-com.co.uk/store/c1/Featur...ducts.html
