tucpal - Replies:
WIPERS
Just changed my window wipers back to the standard origanl Vauxhall ones
i have been using the Bosch wipers for a year now
and i have to say the origanl wipers are much better
the Bosch ones had clips that just stud out to much and would put drops
of water all over the windscreen and this has been very annoying
also the washer jets would hit the clips as there so big
and the origanl ones dont do this i should have changed them back to standard long ago
Auto lights and wipers
Would I be wrong to assume that all that would be needed for this is the window sensor, the windscreen and VCI coding to get this working?
Astra gtc windscreen wipers
My widescreen wipers have a mind of there own flashing on dash saying auto sence on auto sence off and just won't stop unless I pull fuse out it's even got my auto electrician baffled
Wipers
Needs Help ASAP
had a problem since the summer where I have speed 3 on my wipers but not speeds 1&2 I have replaced the battery after being told by The AA the battery was knackered but this has not solved the problem
Any help would be greatly appreciated
