1:st-Sep-2019, 17:56:20
- Anyone no how much gearbox oil the f40 takes
Tags |
f40 gearbox oil amount |
F40 gearbox oil amount
2:nd-Sep-2019, 07:25:56
https://www.vxoc.org.uk/forum/Thread-Lub...ol-Engines
or https://www.vxoc.org.uk/forum/Thread-Lub...el-Engines Astra-J 2.0 CDTI S/S
on the vxr it's recommended to use 2.4 litres, normally 0.4 litres remains in the gearbox during an oil change - so just add two full litre bottles
2:nd-Sep-2019, 19:31:22
Thanks for that .loads of different figures about on this was told 1.9 liters for f40 think I will drain it and see what comes out
3:rd-Sep-2019, 07:30:17
Normally you have 2 bungs a fill and a drain, it used to be you drain it through the drain bung refit it the fill through the fill bung untill it starts to dribble out and hey presto you have the right amount of oil in. I don't know if this has changed though
3:rd-Sep-2019, 13:11:56
Hasn't it got an oil level plug where you fill it until it piddles out?
3:rd-Sep-2019, 18:21:46
No its got drain at bottom and fill on the top
9:th-Sep-2020, 01:40:07
F40, ive read 1.8, 1.9 and 2.0 put in.
Im going for Millers oil 75w90 instead of 75w85, prob 2 full bottles (2L)
9:th-Sep-2020, 10:24:18
There is a thread with info on how much oil you will need.
9:th-Sep-2020, 19:24:05
just bouught 2 bottles of this:
https://www.demon-tweeks.com/uk/millers-...il-780844/ I think they have priced it wrong as its 13 quid everywhere else! 20 quid 2 bottles delivered GL-4 for the F40 box
13:th-Nov-2020, 16:28:55
I put 2.4L in mine but did jack it up to drain it all out.....
2.0 CDTi Auto Gearbox Oil Change | Dennis S | 0 | 1,635 |
13:th-Aug-2021, 14:29:25 Last Post: Dennis S |
Gearbox whine m32 | Nathan191210 | 1 | 1,619 |
22:nd-Feb-2021, 09:18:27 Last Post: Rusty2009 |
2014 Astra 2.0L 165 HP F40 gearbox quantity of oil?? | Kpal11 | 3 | 3,425 |
12:th-Jan-2020, 16:38:41 Last Post: Kpal11 |
Gearbox Oil drain plug? | shabba | 13 | 9,524 |
10:th-Jan-2018, 11:59:11 Last Post: stigeye |
Gearbox Oil Change? | doug143 | 0 | 3,524 |
14:th-Jan-2016, 21:05:49 Last Post: doug143 |
Who read this thread? |
1 User(s) read this thread: |
hursty (20:th-Jun-2023, 11:22:37) |
