cd400 more for basic looking
basic CD400 looking for more
Hi guys not sure if this has been mentioned before but for an upgrade,
64 plate estate
I have CD400 with only aux input, and a standard aerial,
what I am looking for is:-
factory system with Navi DAB Bluetooth & USB
are you able to advise me on the items I will need to be able to have this in my car, would I need new trims to fit as the screen would be bigger (links would be good)
Is there anyone got this kit that are selling?
also would I need to get some kind off kit to program this, (what kit would I need)
I did buy a meta voice M1 system but I didn't really like it and didn't use it, So this system is for sale if anyone is interested
If any Friends out there that could advice me would be smashing
Kind Regards
Dom.....
you will need the control box (behind the radio panel), the radio button panel, the display including the trim, the cable between the display and the control box, plus some wiring mods
However it needs MiDi to enable it and a VCI, speak to Rusty
As Vocky has said you will need the following.
Navi screen (depends what Navi system you want to fit as to which one).
Navi screen surround (which one depends on if you sport/tour VXR button).
Navi control panel (the 600/900 650/950 will all work with whatever unit you fit).
USB plug USB cable (I make my own when installing).
Custom loom for the wiring changes (again I make my own).
DAB module (again depends on what navi you fit as to which one).
BT module (unless fitting a Navi950).
GPS aerial I most fit hidden one's unless customer wants to pay more for a roof one (unless it's a GTC with a dummy shark fin).
DAB aerial, can use a window one or aftermarket roof or factory.
Unless you have almost £2000 to spend on a MDI are willing to pay the GM sign up fee's and can prove your a businesses & your willing to pay the hourly fee's to be able to program forget trying to program yourself.
  CD400 usb and aux not responding ste88 6 2,163 22:nd-Aug-2021, 18:16:19
Last Post: ste88
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 113,444 20:th-May-2021, 09:19:58
Last Post: h4r7y
  CD400 Plus - what does the “Plus” Add? GordyC 9 15,586 12:th-Nov-2020, 10:41:15
  ad usb to cd400 Collie 5 3,672 9:th-Oct-2020, 16:56:47
Last Post: Collie
  GTC BT CD400+ ac1212 1 2,981 18:th-May-2020, 09:51:39
  CD400 buttons not working Android head unit install mephisto 4 7,623 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  CD400 upgrade Astra vxr 2014 Nathan 6 4,930 22:nd-Oct-2019, 20:13:14
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 4,002 13:th-Aug-2019, 06:48:28
Last Post: Schiffers
  CD400 FAULTY kjohns80 2 3,776 7:th-May-2019, 11:05:06
  CD400, in meriva B, mid-speed can-bus off, wont allow can learn gazz292 3 5,003 28:th-Apr-2018, 08:34:44
shadowfire (27:th-Jun-2023, 22:04:11)
