to j gtc what your you done have today? or
What have you done to your J or GTC today?
As per heading
Changed front discs and pads
Changed Fuel Filter
Changed Pollen filter
Emptied the drivers door of water :(
Jobs to do
Change rear discs and pads
Change the door strap as the noise when opening is doing my head in Smile
Buy a parcel shelf
Do a fog light install
and loads of other things and when that's done give it a good detail
(27:th-Aug-2018, 22:07:41)phil67 Wrote: As per heading
Changed Fuel Filter
Jobs to do
Buy a parcel shelf
  • Kicked it!
  • Stared at it!
  • Sat in it!
  • Shouted at it!
  • Prodded it!
Or and fed this fish in the pond(bottom of door water container......) lol
Happy Days.....not!!!!     Buried
It seems that the water in the door is rather common
Yes Phil it seems to be,i have only just got my astra j so dont really know much about the problem but a few of the guys
on here will tell you more than i can buddy....   Thumbs
It wasn't on mine but I retrofitted Navi950 with rear camera into a GTC.
As to the water in the door's Vauxhall put rubber bungs in the bottom of the doors 2 each door rather than letting the water out they hold the water in.
So we always advise to pull the bungs out and leave them out.
Had this water problem with my sports tourer only on rear doors with manual windows ,when adding led lighting to door cards which were off the car had a look at the bottom of door and there was a peice of trimming blocking the two water release holes it had actually came off from a channel that the window went down into the door, removed it stuck it back into the channel water left and not had it come back since,hope this helps
  Plasti dip today Jon3sy 13 12,583 17:th-Mar-2018, 23:16:03
Last Post: Gavinj87
  Parcel today Jon3sy 2 5,151 17:th-Aug-2017, 15:21:51
Last Post: Jon3sy
Sad Blue smoke from a17dte today rbull51 1 6,333 18:th-Jan-2017, 20:55:37
Last Post: Astra VXD
  Few Pictures off today ! Jonathaneuk 12 13,860 11:th-Apr-2016, 17:41:25
Last Post: Jonathaneuk
  Today I mostly.... CRNeo 7 10,016 28:th-Apr-2015, 19:08:26
