lights j gtc daytime running astra
Astra J GTC Daytime running lights
Hi All
Any body have issues with their daytime running lights working one minute and not the next? When I unlock the car, you can see both working fine. Yet when I drive, the driver side doesn't work. Any ideas?
bad connection in the bulbholder?
(26:th-May-2018, 09:27:40)niteram Wrote: bad connection in the bulbholder?
+1
If they are halogen lamps?
(25:th-May-2018, 16:01:33)Wanna_be_dj Wrote: Hi All
When you unlock the car, you're seeing the side lights. When you're driving, you're seeing the DRLs.
In short, the bulb has 2 filaments. The sidelight filament has blown and therefore the bulb needs replacing.
Thank you. Will look for some new DRL's
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,533 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,054 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,574 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,801 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,893 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,027 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,155 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,484 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,811 24:th-Jan-2021, 14:44:22
  Astra J workshop manual Euroshopper 1 1,960 9:th-Jan-2021, 08:09:36
