Trade Count:
0)
Threads: 5
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra j 2.0cdti elite
Sex: Male
Total Feedback: 0
Hi everyone I need help urgently.
Long story short some ***** went into my car door so I’ve got a second hand one which I need to respray. But I need the window down to fully strip it.
I’ve tried powering the main loom but nothing. Even went straight to the motor still nothing.
Can anyone shed any light.
Many thanks.
Trade Count:
0)
Threads: 10
Thanks Received:
1 in 1 posts
Thanks Given: 0
4
Car: Astra-J 2.0 CDTi
Sex: Male
Total Feedback: 0
IIRC you'll need to swap the door modules over from the old door to the replacement one as it's coded to the car or something like that.
Trade Count:
0)
Threads: 10
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Car: Astra J Sport Tourer 1.6auto, Astra J Sport Tourer 1.7cdti 6spd, Astra J 5 door hatch 1.6 5spd
Sex: Male
Total Feedback: 0
17:th-Apr-2018, 21:33:34
(This post was last modified: 17:th-Apr-2018, 21:40:28 by niteram.
Edit Reason: forgot to add something.
I fitted a new (used) front door to mine - I fitted it, plugged it in an it all worked, no module change or coding
I had to fit a new drop glass as mine was damaged and the new door came without glass, but it was the right colour for the car so didn't need painting.
I needed to move the mechanism before fitting the door so stood the new door next to the old, disconnected the wiring at the pillar and plugged in the new one, moved the mechanism to the correct position then swapped the plugs back.
