leaking? conditioning air
Air Conditioning leaking?
I hope someone can help me, I own an Astra Excite 1.4 2015, my aircon seems to be leaking even though it has not been used for a while, I started the car today and ran the aircon on full and water did come out constantly, which I know is normal, but when everything is off, there is a slow drip.
Basically I need to know what do I have to do to stop this
Hap
Welcome to vxoc.
Issue with aircon not being used is seals can fail.
Even when the aircon is used after use you will still get some water on the floor it doesn't mean there is a leak.
If you think there really is a leak get to a garage they can run a dye through it and check for leaks and pinpoint where.
where is the drip coming from?
is it condensation from the air-con or is it coolant leaking?
