diameter of discs front
Diameter of front discs
Hello
Euro car parts are doing up to 55% off today, so I'm after buying front and back discs and pads. I can get the lot for £156.46!
Problem is I'm unsure of the diameter of the front disc. Euro car parts say that there's 2 types 300mm and 321mm I've just measured mine and they're 280mm!
Cars a 1.6t 2010
My bad. Had another measure they're 300mm front
300mm front and 292mm rear if your car has 5x115 pcd wheels. 276mm front and 268mm rear if your car has 5x105 pcd wheels. VXR has 355mm front and 314mm rear discs.
Cheers mate. Thats what I ended up ordering 300mm front 292 rear.
Any idea what the labour would be to get them replaced?
I would have thought about an hours labour at the most at a garage, so whatever your local charges per hour. Put it this way, it was just over an hours labour for our garage to remove both gtc front struts and change springs and then refit them. This included removing the discs and calipers first, so removing caliper and changing just the discs would be even quicker.
Well they're all fitted now. £40 plus vat an hour, took 2 hours. Saved about £8 in the end with buying my own parts at a discount. Ha.
I bought Pagid discs and pads for the front and Eicher discs and pads for the back which where a lot cheaper than the Pagids
What brand do Vauxhall use? Are the pagids any good?
(19:th-May-2017, 10:22:49)dutton84 Wrote: What brand do Vauxhall use? Are the pagids any good?
Delphi among others, IIRC.
Pagid is a reputable brand.
  Head restraints on front seats horizontal adjustment imendes 1 6,089 28:th-Apr-2017, 19:23:16
Last Post: bhalay207
  Facelift front grille hostilehaggis 2 8,030 28:th-Sep-2016, 22:46:07
Last Post: hostilehaggis
  Front Seats Dannydyer 2 6,684 20:th-Feb-2016, 21:31:09
Last Post: Dannydyer
  People with front and rear sensors Kris 14 17,392 28:th-Jan-2016, 23:06:27
