6:th-Jul-2017, 20:59:46
(6:th-Jul-2017, 19:43:39)Jon3sy Wrote: What did you go for after ?
Dis
s progression connah |
Connah's progression
(6:th-Jul-2017, 19:43:39)Jon3sy Wrote: What did you go for after ? Dis Sent from my iPhone using Tapatalk Pro
6:th-Jul-2017, 23:05:32
Looks good mate
6:th-Jul-2017, 23:08:31
You can see the difference in the quality of steel they use vs vauxhall. I got a long middle one instead of a back box because the back box causes alot of restriction whereas that middle bit doesnt because its just a pipe with a bit of padding around Sent from my iPhone using Tapatalk Pro
9:th-Jul-2017, 10:58:43
And here is the back end of my car up to now Sent from my iPhone using Tapatalk Pro
9:th-Jul-2017, 14:41:39
Thought might of gone for one on the other side.
(9:th-Jul-2017, 14:41:39)Rusty2009 Wrote: Thought might of gone for one on the other side. I was going to but see the little bump above the tip? There wouldnt be one on the other side so it would look weird and also i wanted performance so had a really long middle box rather than a back box so its just a straight pipe Sent from my iPhone using Tapatalk Pro
10:th-Jul-2017, 07:08:53
I've never noticed that bump before.
10:th-Jul-2017, 15:42:00
31:st-Jul-2017, 22:33:02
So i have done quite a bit since last posting. I have put groot up on the dash
I have put a dtuk tuning box in the car. It didnt seem to do much but after playing with the settings it seems to have done the trick! Its such a feisty car now but it likes to change down two gears instead of one when i kickdown (auto) so i have played with the pedal box to basically increase the distance that i need to push for the second gear shift down which has worked so very happy with the result up to now I put a rear lip protector on which will help if the gf accidentally slips and the wheelchair drops and it matches the colour scheme i was going for Also put on the dash cam sticker to hopefully stop people getting up my ass Sent from my iPhone using Tapatalk Pro
5:th-Aug-2017, 17:13:30
I have done a couple of mini mods to make my life a bit easier. I have put one of those things to stop stuff falling in between seat and centre console so it stops that ballache when i it happens.
6:th-Aug-2017, 07:34:57
I saw them gap fillers seem a good idea do you have a link where you got them from?
6:th-Aug-2017, 10:51:44
(6:th-Aug-2017, 07:34:57)Rusty2009 Wrote: I saw them gap fillers seem a good idea do you have a link where you got them from? Aliexpress! https://m.aliexpress.com/s/item/32788220...53eb8vxOLj& Sent from my iPhone using Tapatalk Pro
8:th-Aug-2017, 09:40:01
wow, $4! thanks, they'll come in handy for sure
2009 Insignia Sports Tourer / (EDS) Remap 202hp/475Nm / (OEM) DAB+ retrofit / (OEM) Foglights retrofit / (Focal) sound system
8:th-Aug-2017, 12:33:12
(8:th-Aug-2017, 09:40:01)zzattack Wrote: wow, $4! thanks, they'll come in handy for sure Mate the amount of times i have dropped my phone down the gap is ridiculous! It stops crap getting down there aswell so when you clean your car its easier aswell Sent from my iPhone using Tapatalk Pro |
« Next Oldest | Next Newest »
Possibly Related Threads… | |||||
Thread | Author | Replies | Views | Last Post | |
Progression Thread: TUFFKNUX | TUFFKNUX | 3 | 4,711 |
14:th-Feb-2015, 16:14:06 Last Post: TUFFKNUX |
