a f40wr remap on
Remap on a f40WR
Evening all,
I just picked up an GTC 2.0 CDTI 165 and was wanting to get it remapped, on paper the car goes from 165bhp to 350NM to 200bhp with 440NM which looks fantastic.
The worry I have is according to several online sources the gearbox is only rated for 400NM and I was wondering if anyone has been in a similar situation and could say if the gearbox held up okay?
Cheers!
Ross
Correct me if I'm wrong but it's the same gearbox as the Vxr and I'm sure they pump out more than 440 nvm
Cheers James
The gearbox on a GTC VXR is F40CR I believe, and according to VX own website and various other sources the torque is 400Nm, not sure what it is rated at though. I wouldn't consider having a car mapped past it's threshold, not unless you like spending money on replacing the clutch gearbox etc etc.
there have been plenty who have gone up to 200bhp on the 2.0 cdti with no problems
anything over that is pushing it for sure if it is a custom map you could get them to go for 190 and lower the NM nearer to 400NM
i would be wanting the EGR delte mapped out also but keep the DPF as you may have MOT problems
Thanks for all the replies lads!
Running around 215bhp and 460nm and over a year of driving hard from 2nd gear to 5th and not had a issue. Gearbox is pretty solid.its the clutch and dmf that takes more of a hammering.
A Vectra VXR is pushing 355Nm. The VXR gearbox is rated 400Nm. But the rating is not peak performance. It is rated in constant pressure of 400Nm. Therefore is has no problem handling 500-550Nm.
  Remap / New Member, Hi! MidlandsGTC 1 4,581 5:th-Jan-2021, 08:42:56
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 11,000 11:th-Sep-2020, 20:55:21
Last Post: badger64
Remap? LINNY34 14 16,310 27:th-Jul-2018, 19:07:38
  !.4 Turbo remap Midlands simsgtc 5 7,006 15:th-Jul-2018, 21:51:29
Last Post: simsgtc
  My remap nightmare Morgan 43 34,082 11:th-Mar-2017, 08:33:25
  dpf removal and remap on a17dte? rbull51 4 8,288 1:st-Dec-2016, 23:02:47
  ECU Remap or Pedal Box bradhiggy 4 7,838 1:st-Nov-2016, 14:08:31
Last Post: bradhiggy
  Remap results Starie 2 5,752 19:th-Jul-2016, 22:38:23
  62 2.0 CDTI Elite remap Ukgeezer 9 11,226 12:th-Jul-2016, 11:02:02
Last Post: marcus
  Remap Help sheppy1 23 19,236 14:th-Mar-2016, 08:16:46
Last Post: bhalay207
