headlight xenon numbers part
Xenon Headlight Part Numbers
I saw a 2010 5 door elite today with headlights like these:
Are these standard? If so does anyone know the part numbers ( and if they will fit my J that's non xenon )
(sorry if I have posted in wrong section)
Thanks.
2012 Astra J 2.0 cdti sri
No they won't fit none xenon models. They need not only programming but major wiring changes.
AFL lights are optional extras. I don't think they are standard on the elite
As bhalay has said there are major wiring changes needed and also programming & GM no long support AFL retrofits.
Correct not fitted as standard to any model it's an option.
It seems I was luckily with the AFL retrofit I did.
(13:th-Aug-2016, 23:48:22)D92 Wrote: I saw a 2010 5 door elite today with headlights like these:
Thanks.
You can buy after market projector headlights which will look similar for around £300-£350 and they will be plug and play, so just a matter of fitting, but they are still xenon though.
Cheers all,
Was hoping they would fit, all the aftermarket lights dont look nearly as nice.
Closest I can find are the Magneti lights ( http://www.ebay.co.uk/itm/400968932903 ) but not sure If they will fit my 5 door, advert on ebay says both gtc and non gtc, but I thought the gtc had different lights or am I wrong?
They are GTC lights and will only fit a GTC.
These lights are nice...
They can be found here... http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...SwzJ5Xf6jm
  Navi 650 Screen Surround Part Number Jetcolour 9 9,216 4:th-Jan-2021, 14:01:10
Last Post: MarkAP68
  Headlight Switch Disassemble Jetcolour 3 2,743 15:th-Dec-2020, 20:51:36
  Part Number Required Traders 2 6,881 23:rd-Sep-2020, 08:50:29
Last Post: Traders
  Need help identify part. LucasBritish 1 7,499 22:nd-Jun-2020, 11:48:35
  Need help identify part. LucasBritish 2 2,651 22:nd-Jun-2020, 11:44:44
Looking for this part, see picture Budd 3 8,655 15:th-Feb-2019, 18:41:41
Last Post: Budd
  looking for part number then try here. Rusty2009 11 13,030 11:th-Jan-2019, 11:48:11
Last Post: Ykrats
  Boot rubber thing part number Telsun 0 7,604 2:nd-Jan-2019, 21:07:37
  Need a Part number Eddie0892 10 10,900 22:nd-Nov-2018, 14:05:53
  Astra j headlight repair kit workshop manual Cameron UK 4 8,763 18:th-Dec-2017, 19:41:33
