negative loss memory terminal
Memory Loss Negative Terminal
HI all
just a quick question. If i remove the negative battery lead for an hour will i lose all the cars settings radio code ect ect
Car is a 16 plate gtc
The radio doesn't have a code as its vin locked to the car.
Iirc most the settings stay you will have to do the time and maybe retune your stations
Everything will remain as it was before removing the battery. Your clock and date may be out of sync but if you've set it to update with RDS then it will be sort itself out. There's no need to reprogramme the stations
  1.6 cdti power loss ihastings 25 32,118 19:th-Oct-2018, 07:37:42
  Slow coolant loss Dennis S 21 32,551 8:th-Jan-2018, 11:13:20
Last Post: Dennis S
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 27,294 23:rd-May-2017, 07:00:23
  Help diagnosing loss of power Thebatfink 9 16,284 6:th-Jul-2016, 07:23:31
