water loss
I am loosing coolant about 250ml every 2 months. As the car was in for a recall re the coolant fan overheating problems which they phoned just before Christmas about I asked if it could have anything to do with my problem of the water loss.
I was told that the radiator fan on some 1.4 T Astra’s were overheating and the cure was to remove the battery cover. At that point I burst out laughing. The battery cover is nowhere near the radiator let alone the fan, so how will the removal of the cover
Memory Loss Negative Terminal
HI all
just a quick question. If i remove the negative battery lead for an hour will i lose all the cars settings radio code ect ect
Car is a 16 plate gtc
Help diagnosing loss of power
Hi. I have a 62 plate 2.0CDTI Elite manual gear box. Its all fully standard except the DriveAudio headunit.
On Tuesday I went to Manchester and back (170 mile round trip) no problem. On Wednesday I went up Bradford way, again about 170 miles odd (I don't do these types of runs every week mind).
Well on the way up Bradford, no problems. But after work I get in the car and shortly later I get a 'Service Vehicle Soon' message. I just clear it thinking its reminder to service as the car seems
2.0cdti ECU update for DPF causing poor fuel & loss of performace
So when my car had Turbo issue's the dealership did a software update to the ECU.
This update is related to the DPF
Quote:It adjusts the parameters for the dpf temperature sensors to improve dpf performance and avoid overloading dpf, eml lights and in worst cases engine stalling.
it's a software weakness that only effects astra j, cascada and zafira tourers up to model year MY13.5. The update will just adjust the software weakness that is present.
At first I didn't notice
Slow coolant loss
My 13 reg Astra 2.0 cdti auto tourer is losing coolant somewhere. I noticed the level in the expansion tank was low in September and topped it up. Then just last week I got in and had a low coolant warning on the dash. It took about 600ml to top it back up.
There are no obvious leaks to see without dismantling anything, and there's no mayonnaise inside the oil filler cap. The car's done about 59000 miles.
Does anyone have any ideas where to look, or any common faults that might cause this ?
T
1.6 cdti power loss
Hi Folks, I've recently bought a 2014 astra 1.6cdti sports tourer techline which is giving me no end of trouble...
When I collected the car from Arnold Clark I didnt think anything of the "Service Vehicle soon" message when putting the key in the ignition as I'd mistakenly assumed that the service warning hadn't been reset following the pre-sale service. Turns out, as I found out the next day, that the DPF had issues as when turned on ignition to set up my phone with the headunit, the dispaly
Power loss and stop start not working
Hey guys
I have a 62 plate astra J 2.0 CDTI.
I have noticed a few things and wondering of could shed some light on things to check.
1) my rev needle is sitting at 500 revs (not sure if that is low and then at times it fluctuates.
2) when driving and trying to set off it just doesn't seem to have the same power. It's intermittent but at times the power just don't feel there
3) The automatic stop start doesn't work anymore, or shall I say majority.of the time it doesn't work and then here an
Loss of power
Last night i was driving my GTC 1.4t down the dual carriageway after cruising for about 30miles, came up to a roundabout and went to accelerate up to speed... Next to no response from engine, car flashed up saying "Service Vehicle Soon" and takes forever to get up to any speed above 20mph. Dangerous for joining Dual Carriageway on my journey to work so i have had to change my route to compensate.
Car can get up to speed (had it up to 70mph last night), but just takes an age to get
Intermittent low loss of engine power
Hi all hope you’ve all had a great Christmas.
I’m experiencing a strange fault/ feeling with my 1.7 Cdti Astra.
At times it feels like the engine is a bit flat and other times it’s normal, I have also noticed a very slight hesitation under normal acceleration. It sometimes feels like a non turbo engine. No apparent leaks on the pipework and no engine management light on. Has anyone had any experience of similar issues, I’m thinking either the turbo’s on its way out or the boost pressure sensor
Astra J Total power loss
I had total power loss in my 2013 reg astra J sri .
There was a problem when i drove the car in that the power steering was very hard to turn steering wheel but then back to normal.
!0 minutes later suddenly All power went on the car without warning.. No lights, engine died, total power loss...
Tried jump starting but still nothing happens & all connections to battery seem ok...
Only thing i can think of is that i got battery changed 3 weeks ago so maybe a loose wire somewhere.
Could it
