indicator bulbs silvertech
Silvertech indicator bulbs
Just fitted some Silvertech Indicator Bulbs.
The Silvertech have a Mirrored Finish to the Bulb so they Do not look Orange
in the Unit for the Indicators and Fogs at the front.
Here are the Silvertech Bulbs
They are made by Phillips and are very good
there an Extract match for the Original
but much Better Looking with the Mirrored Finish
here is the old Orange Bulb and the Silvertec Side by Side
so you can see the Difference.
Here are a Few Pictures of the Original Orange Bulb
in the Unit you can see how Orange they look.
And Here are the Silvertechs
they look so much Better in the Unit
they do not have an Orange Tint at all.
Absolutely a top Product here Does Exactly what is says it does
Remove the Orange Tint from the Light Unit
they look so much Better i am Really Happy with them
they are Error Free also
and they are Nice and Bright.
To fit the Bulbs on the Pre Face Lift Astra j is some what Tricky
you can get your Hand up to the Connector and get the Bulb out and Back in
but it is very, very, Tight
but it is Possible but some what Tricky.
To show you How the Clips etc comes off and Goes back on
on the Pre Face Lift i took the Front Bumper off
to get some better Pictures.
STEP ONE.......
Remove the white Connector
And Press the Tab on the Top of the Connector
and Pull it out.
STEP TWO.......
Push down on the Squire Clip on the Right Hand Side
and Pull the Clip away.
STEP THREE.........
Simply pull out the Bulb
Note it only Goes back in One way
And Refit in Reverse.
The Face Lift is much Easier to get Access to the Bulbs
so you will not have much of a Problem at all
if you have the Newer fog units.
Very happy with the out come
A Very good Product.
Pretty sure they are the indicator bulbs you get on the GTC when you have AFL's
Top job these are on my list.
i am Very happy with them they look much better
and give an over all cleaner look to the light units.
Yes John these are deffo fitted to AFL lights
still a good upgrade for those who don't have AFL then.
Excellent upgrade it's always the first thing I do as I can't stand the egg yolk look
I did prefer it, when we had orange lenses instead of these clear things with orange bulbs inside. At least it gave a bit of colour to the car.
my metal clip fell off, and i cant get it back on, ahh, gonna have to take my bumper off arent i, dont want to
where can i get some of these silverteck bulbs, i'll take my bumper off to fit them, hopefully the 1 thats in atm, will just sit where it needs to be without its metal clip
the clips are a pain i had to take my bumper off to get them in
  How to change drl and h7 bulbs tucpal 74 58,802 17:th-Jun-2019, 10:42:44
greg848484 (11:th-Jun-2023, 18:44:37)
