13:th-May-2016, 14:53:18
i bought a 12 gtc which i pick up next week. is it worth taking out an extended warranty on it or are they a waste of time
extended warranty |
extended warranty
13:th-May-2016, 15:04:11
It's upto you I'd highly recommend you make sure you know what is covered and really read the small print.
I wouldn't take out extra warranty myself. Sent from my iPhone using Tapatalk Astra-J 2.0 CDTI S/S
13:th-May-2016, 15:19:03
the garage said it through the aa there 5 star warranty. the only reason im thinking of doing it is because the car is second hand and i have no idea about it
13:th-May-2016, 15:24:51
Depends how much it costs tbh... If it's only cheap then yeah go for it
13:th-May-2016, 15:31:45
it was £299 for 1 year £499 for two which was cheaper than i seen online
13:th-May-2016, 15:40:38
I work with a guy that takes these out with every car he buys and he has had the use of it with the past 2 days.
That was an AC unit on 1 car including belt which snapped due to the unit seizing. The other was a gearbox problem which was fixed but his only covered something like £1500 for a year.
13:th-May-2016, 15:45:22
from what i gather they cover £2000 per claim after that you have to find the rest
I would look around more, you can get some good deals but you have to do a detailed search. Think of the things that are expensive to replace and ask if those items are covered. What GTC have you bought, what trim (SRI, Sport etc) what engine size?
Have a look at click4warranty.. I did a random check and I was given the following prices... Take the £3000 pa cover for 3 years and you pay the following...
its a 2.0 cdti sri 21,000 miles
http://www.hiltongarage.co.uk/Used-Car-D...68186.aspx the guy said it covers everything electrical and mechanical except wear and tear items
13:th-May-2016, 16:11:17
(13:th-May-2016, 15:56:21)evo Wrote: its a 2.0 cdti sri 21,000 miles If it doesn't cover wear and tear items you may as well forget it.
13:th-May-2016, 20:14:04
Put a Lil bit of money in a jar for car repairs, I've always done that for my cars and animals as I've had my fingers burnt with warrentys/insurance etc
15:th-May-2016, 16:02:26
(13:th-May-2016, 16:11:17)stigeye Wrote:No warranty will cover wear and tear items unless they've failed as a result of another none wear and tear item failing.(13:th-May-2016, 15:56:21)evo Wrote: its a 2.0 cdti sri 21,000 miles Sent from my LG G4 using Tapatalk (15:th-May-2016, 16:02:26)bhalay207 Wrote: No warranty will cover wear and tear items unless they've failed as a result of another none wear and tear item failing. LICK4WARRANTY INCLUDES COVER FOR WEAR AND TEAR AS STANDARD Click4Warranty includes protection against both "mechanical breakdown" and "wear and tear", so your Click4Warranty policy WILL pay toward the cost of repairs if a part fails as a result of “wear and tear”. Sometimes this means your car is in a better condition than it was before the breakdown. If this is the case we will ask you to pay a contribution toward the cost of repairs. HOW WE HANDLE WEAR AND TEAR CLAIMS We cover wear and tear from the first day of cover. If you make a valid claim that is attributable to wear and tear, and your car has covered less than 60,000 miles, we will cover the claim in full (up to your chosen claim limit.) However, if your vehicle has covered more than 60,000 miles it’s not unreasonable to suggest that if, for example, your gearbox was repaired the car is actually in better condition after the repair than it was before. In this instance we would call for a contribution toward the repair costs. For example, if your car has covered 67,000 miles, we would require a 10% contribution i.e. on a £350 claim, you would be required to pay just £35. As with all aspects of our products and service, we aim to provide clear information. The table below shows the contribution toward the cost of repair you will be required to pay depending on the mileage of your car at point of breakdown. Up to 60,000 miles no contribution required Up to 70,000 miles 10% Up to 80,000 miles 20% Up to 90,000 miles 30% Up to 100,000 miles 40% Over 100,000 miles 50% I could list quite a few warranty suppliers who cover 'wear and tear' as standard just from a simple google search. In regards to click4warranty, I have gone through their policy terms and conditions and there is their are no exceptions to the wear and tear policy, only items that aren't covered. They even cover timing belt failure as long as the it hasn't gone past the car manufacturers service instructions on when it should be replaced.
16:th-May-2016, 09:53:34
Actually sounds really good and like something I'd consider... But I bet it would be like pulling teeth getting them to pay out! Ha
16:th-May-2016, 10:44:30
That's surprises me. Warranty companies are the first to run in the opposite direction when the words wear and tear are mentioned
21:st-May-2016, 09:40:04
So I purchased an extended 3 year warranty when I bought my car from Eden, to be honest it was thrown in as part of the package (don't be afraid to walk away) but would have cost £499. No doubt I paid for it in the inflated cost of the car so swings and roundabouts I guess.
I drive my car everyday for work, was doing around 55 miles a day, now doing 25. Mostly motorway. I had the dreaded drivers heated seat problems covered here, which I didn't pick-up (or even know about..who would) when I bought the car: https://www.vxoc.org.uk/forum/Thread-HOW...ER-ASTRA-J Warranty covered it, I saw the bill for this, it would have cost me £420. I also just had both my rear springs fail after a trip on the motorway, luckily it waited until I had pulled up at home and I heard this loud "PING". Took it to the garage, one was obviously failed, then they did a safety check and found the other had failed as well. The car has only done 50,000 miles (2011 2.0 cdti ecoflex). The warranty covered these springs with no problem, which I am glad because springs should not fail after that many miles. The bill for this would have been just shy of £150 at a guess including labour (didn't see this one) So for me the extended warranty has already paid for itself, It runs out the end of next year so plenty of cover left for anything else that decides to go wrong. I know lots of people have problems with Eden, for me its been absolutely fine so far and I wouldn't think twice about getting a warranty from them again. Lets hope I continue to say this by the time it ends. |
Warranty diagnostic fee? | everson38 | 4 | 2,868 |
7:th-Jun-2019, 10:49:39 Last Post: everson38 |
