2:nd-Apr-2016, 20:42:07
Hi is this broke it goes into reverse without the lever
Tags |
stick broke ? gear |
Gear stick ( broke ? )
2:nd-Apr-2016, 20:54:23
Does the lever reverse back as usual or do you have to pull it back in resting position?
2:nd-Apr-2016, 21:12:13
No all as normal just if I go for 1st it will allow me to go to reverse without lever being pulled up no stop gate of you know what I mean.
3:rd-Apr-2016, 14:08:46
There is no way you can put it in reverse without lifting the lever. Can't see very well on the picture if it's broken or not fitted correctly.
3:rd-Apr-2016, 14:15:08
Trust me it goes into reverse with no effort just like going into 1st.
3:rd-Apr-2016, 16:20:41
Hello there,
Was doing something else with the my car and had you in mind... took a picture from my gear stick mechanism... Red circle = block you move with the lever on your gear stick Yellow cicrle = barrier which should prevent you from chose reverse gear Is it working?
3:rd-Apr-2016, 21:12:37
have you played about with the two cables at all if so they will need to be reset correctly
7:th-Apr-2016, 08:24:45
@Daz21 where in Wiltshire are you I'm in Swindon and could have a look for you
7:th-Apr-2016, 10:37:59
(7:th-Apr-2016, 08:24:45)cornishtaz Wrote: @Daz21 where in Wiltshire are you I'm in Swindon and could have a look for you hi not far ur just up the road lol i have sorted it now thanks tho
6:th-Dec-2017, 23:31:24
I have the same issue, how did you resolve? Thanks in advance.
Can't get in gear - clutch problem? | klargon | 0 | 3,068 |
9:th-Dec-2017, 16:21:11 Last Post: klargon |
Damaged gear knob trim | chrisb2511 | 12 | 7,134 |
26:th-Jun-2016, 11:54:28 Last Post: M1C VX |
Gear lever vibrates | Regi | 8 | 7,674 |
15:th-Feb-2016, 09:23:57 Last Post: Regi |
Retrofit gear stick surround ambient light | sotoskon | 14 | 10,556 |
14:th-Feb-2015, 15:27:52 Last Post: tucpal |
LED GEAR KNOB | tucpal | 5 | 5,767 |
7:th-Feb-2015, 23:43:07 Last Post: tucpal |
