sensors parking
Parking Sensors
Is the parking sensors from an astra estate the same as the hatchback?
Whats the best way to spray them? Is there a company that does it.
There the same
(22:nd-Jan-2016, 15:34:34)tucpal Wrote: There the same
Cool, Thank you.
I have bought these parking sensors for my retro fit.
http://www.ebay.co.uk/itm/391264040971?_...EBIDX%3AIT
Do i need a bracket to fit them to my car as they appear to be the flush mounted ones. Also how would i go about spray painting them?
I found the answer but i cant seem to find where to buy them from. I cannot see them on autovaux.
20 14 54 005 BRACKET, SENSOR, REAR, RH, OUTER 0
20 14 54 007 BRACKET, SENSOR, REAR, RH, INNER 0
20 14 54 004 BRACKET, SENSOR, REAR, LH, OUTER 0
20 14 54 006 BRACKET, SENSOR, REAR, LH, INNER 0
yep you need brackets try autovaux
(22:nd-Mar-2016, 20:07:42)tucpal Wrote: yep you need brackets try autovaux
I tried that autovaux part number and searching the site but i found nothing.
Il either have to phone them up or i will just keep looking for a different part number and searching again.
You wouldnt happen to know what the bolt was for the steering wheel either would you?
rusty may help you
(22:nd-Mar-2016, 16:05:12)AlexFitton Wrote: I found the answer but i cant seem to find where to buy them from. I cannot see them on autovaux.
Put them part numbers in online, you will be best of getting a body shop to drill the holes and bond them on.
Unlike the kit Tucpal linked you to those brackets are what they would use at time of manufacturing the bumper whereas the one's in the kit are designed to clip together.
I have emailed autovaux to see if they can help me.
I cannot find the brackets anywhere on the internet.
Spoke to autovaux these should he the correct part numbers however they dont have them on the site so fingers crossed the correct ones.
12777468 BRACKET, SENSOR, REAR, RH, OUTER 0
13294648 BRACKET, SENSOR, REAR, RH, INNER 0
12777466 BRACKET, SENSOR, REAR, LH, OUTER 0
12777467 BRACKET, SENSOR, REAR, LH, INNER 0
How do you connect to the sensors?
Don't you need the factory wiring loom with plugs?
(27:th-Apr-2016, 09:03:07)THEHITMAN Wrote: How do you connect to the sensors?
Yes factory loom or if you can find all the connectors and pins you could make your own loom/s
  fitting factory parking sensors Michaelsearle2699 4 6,940 28:th-Jan-2021, 10:29:51
Last Post: Michaelsearle2699
  Navi 950 instead of CD400 + parking sensors DanielG 15 20,802 6:th-Dec-2018, 22:48:19
  Parking Sensors - Enable Distance Farrael 1 5,808 14:th-Aug-2016, 20:39:59
Last Post: Hummelshøj
  Fitting Parking Sensors on a Tech Line THEHITMAN 4 8,469 27:th-Apr-2016, 20:13:06
  Tire sensors Dannydyer 4 9,448 8:th-Feb-2016, 23:20:59
Last Post: Dannydyer
  People with front and rear sensors Kris 14 17,405 28:th-Jan-2016, 23:06:27
