6 j transmission astra auto 1 16v
Astra J 1.6 16v Auto Transmission
How can you find out what Auto Box is fitted to your car?
6T40
https://www.vxoc.org.uk/forum/Thread-Eng...mbinations
(12:th-Jan-2016, 18:45:28)Rusty2009 Wrote: 6T40
Based on that information it is a 6T40 which I believe it also Has an external trans cooler fitted.
Can somebody please confirm?
DP
I've been to have a look and the transmission pipes are connect as in the link, it seems that mine is the AF40 Gearbox.
http://www.partsbase.org/opel/astra-j-20...and-hoses/
it will be the af40
according to this it should be the 6T40
it would help me if i knew what engine you had
it does state it in the thread title
there is only one gear box fitted to the 1.6 auto 6t40
what's the problem with it
Nothing is wrong,  but I have been trying to find the external trans cooler that is illustrated in this diagram:
http://www.partsbase.org/opel/astra-j-20...pt-turkey/
but mine resembles this diagram:
on the side of your gear box there will be or should be a sticker
this will give you an alpha code and part number have a look for that
that may help you out
or go to lookers and give them your reg number this will give them the info they need to identify it for you
What is lookers?
where are you from the car dealers lookers
(12:th-Jan-2016, 21:05:55)tucpal Wrote: it will be the af40
(12:th-Jan-2016, 22:13:04)tucpal Wrote: where are you from the car dealers lookers
South W
is the trans cooler mounted on top of the radiator or to the side?
is this what you are seeing the water hoses
http://www.ebay.co.uk/itm/Astra-J-1-6-Pe...Swo3pWcBrY
Well, I cant see nothing mounted on top, the is a plastic cover, not sure it might be behind that, can't be taking it apart tonight.
DP
(12:th-Jan-2016, 22:27:12)tucpal Wrote: is this what you are seeing the water hoses
looks familiar,  where are the transmission fluid hoses positioned
Found this sticker on the gearbox,  any ideas what it refers to?
(will try and get a better picture)
  auto fold mirror modules Qaranc 4 1,952 11:th-Jan-2023, 01:49:50
Last Post: Qaranc
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,744 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 1,607 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,160 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 4,234 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 4,463 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,922 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,080 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,212 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,558 2:nd-Feb-2021, 09:39:35
