passenger floor astra 0cdti 2 sri puddle
Astra 2.0cdti sri puddle passenger floor
I have an 11 plate Astra 2.0cdti sri. I have been having problems with a puddle appearing on the passenger side floor. There are no other wet areas of the car, and it doesn't happen everytime it rains. I saw a youtube video of an older vectra that had the same issue and it was caused by a drainage cup? under the front screen getting clogged up. I think i might have the same problem as it doesn't happen everytime it rains. I had a look around that general area but as i know next to nothing about cars i have no idea what I'm looking for. Has anyone had the same issue?
Check pollen filter if wet replace pollen filter remove blower motor check if wet this was an old problem with water trailing down the wiper arms inside the scuttle panel the GM fix is to tie a zip tie around the drivers side wiper arm in the scuttle panel about an inch up near the sticker on the wiper arm motor have not heard of this for a good few years now
What tucpal said mate, usually any water in the passenger side of cars is down to the pollen filter getting clogged
There is a TSB for this I'll dig it out tomorrow.
Thanks for the reply guys
here's the link to the TSB
http://vxoc.org.uk/Images/vxoc%20astra-j...ngress.pdf
my car did this when i first got it they did fix it
and they did do the above how to and add a zip tie
i have had no problems since
  New AutoDipDown module for passenger mirror A20DTH 2 1,973 21:st-Oct-2022, 09:33:44
Last Post: rlievens
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,744 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,160 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 4,234 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 4,463 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,922 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,080 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,212 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,555 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,857 24:th-Jan-2021, 14:44:22
