Trade Count:
( 0)
Threads: 27
Thanks Received: 0 in 0 posts
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
Hi guys,
A year or so ago I had a 1.7 CDTI J which occasionally at low speeds you'd hear a fluttery noise when you lifted of, I never had the cad long so didn't worry. It was a 73k car.
I now have a car with the same engine (125bhp) and its doing it all the time, I can drive along at 60 & if you listen carefully and take your foot off the accelerator it will flutter. I'm now panicking the turbo is on its way out (112k) - anyone else get this noise? I'm wondering whether to chop it in before it's too late.
Help?
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
The wife's pug had started doing it 180k got the mechanic to check it out and he said nothing to worry about.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
The 1.7 cdti does seem to make strange noises lots of complaints about that one
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
A Peugeot at 180k!? That's a rarity in itself
Trade Count:
( 0)
Threads: 26
Thanks Given: 0
0
Total Feedback: 0
Is this the turkey noise that plagues the 1.7's? I've had mine done under warranty 2yrs ago but it's come back now
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
Think it must be, after reading it looks like it's the fuel filter.. Will change it tomorrow and see.
Trade Count:
( 0)
Threads: 26
Thanks Given: 0
0
Total Feedback: 0
Think they changed fuel filter and fuel pipes. I was given the worksheet on here when I posted about it, I'll try and find it
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Think it will be in common problems section
Trade Count:
( 0)
Threads: 26
Thanks Given: 0
0
Total Feedback: 0
Here it is Whirring noise http://www.vxoc.org.uk/forum/showthread.php?tid=317
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
Cheers, is there a charge for Vauxhall to do this it is it covered as its a common problem?
Trade Count:
( 0)
Threads: 26
Thanks Given: 0
0
Total Feedback: 0
Outside warranty I think so. They've said its not harming any components it's just air going through the filter
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
17:th-Aug-2015, 08:52:15
(This post was last modified: 17:th-Aug-2015, 08:54:34 by Jj0063.)
OK thanks, I've just been and collected a new filter so will fit it tonight and see if it makes a difference! Cheers
Just listened to the vids, same noise as mine.
Strange as it sounds just like turbo flutter!
Trade Count:
( 0)
Threads: 26
Thanks Given: 0
0
Total Feedback: 0
Strange it is, thing is its louder outside so quiet embarrassing lol. I made the vids because Sod's law the car wouldn't do it when I took it in thankfully the guy there knew about it. Let me know if just changing the filter works
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
Sorry for the delay I've been working a lot and only finished at 4 today. Decided to change the filter as soon as I got home... Easiest thing ever!
Jack rear drivers side up slightly (I didn't even have to lift it so the rear wheel lifted, just took the suspension up.
36mm socket/adjustable spanner to undo the filter whilst having a tray or something to catch the diesel in
Spin the filter/bottom off, let the diesel drain for a few seconds
Swap the filter over, change the blue seal on the filter housing
Screw the bottom back on, nip it tight with the socket/spanner
Done!
Took me 15 mins all in, the car will start straight away and run for ~20 secs as there's fuel in the pipes/injectors but it will then stop and won't start as the filter housing has no fuel. Turn the ignition on and leave it for the pump to prime.. Do this 6-8 times. Then turn it over & it will eventually start.
Just took it up the road & no flutter noise! Il give it a good run tomorrow to be sure but it seems to have fixed it.
Guess il just get used to replacing the fuel filter every 5 months/9000 miles!
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
It's wrong though lol. You don't need to touch the sensor, battery or fuel pipes.. It's just creating unnecessary work.
I had seen the how to but decided against doing the parts that are completely unnecessary
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Ah ok you can add your way to the how-to keeps it one place for others.
