Trade Count:
( 0)
Threads: 1
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Does anyone know if it's possible to add infinity as the standard system isn't as good as my corsa d was so want to upgrade to infinity if possible. Any ideas?
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Should be possible you would too look into the wiring etc and parts needed, although it may work out cheaper to change speakers and and install an amp.
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
Want to try and do it so all looks factory spec
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
1
Sex: Undisclosed
Total Feedback: 0
I don't know about the speakers but the amp in the boot is plug and play so check you have the plug?!
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
Where would the plug be?
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
This is something i wondered, but couldn't find anything online about it.
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
16:th-May-2015, 07:52:03
(This post was last modified: 16:th-May-2015, 08:41:55 by Rusty2009.)
IIRC it is located in the o/s rear behind the trim panel in the boot.
I can look into getting all the wiring and pin outs if you want.
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
1
Sex: Undisclosed
Total Feedback: 0
^^^^ what he said
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
Ok I'll have to have a look thank you
So if the amp is plug and play. Are they the same speakers or do they need upgrading too
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
different speakers from the standard also
but check the factory sub as that is also needed
J1ODAY may show you some pictures
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
Can't find the cable in the boot for the life of me
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
there not in every car and i would have a commandant guess no of the cables will be there at all
sure rusty could work the wiring out for you but this wont be a cheap upgrade
and an after market amp would work out ££ cheaper
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
Don't know if it makes a difference but car is 2014 Vxr
Yeah I know it would. Just I like hidden and discreet
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
i am sure when rusty has the time he will look into the wiring and parts needed
very possible to do it i would look for a car that is braking that has infinity
hard to find but it would save you money if you can find the amp and sub second hand
Trade Count:
( 0)
Threads: 41
Thanks Given: 0
0
Car: Astra J VXR
Sex: Male
Total Feedback: 0
I did get a price from the local dealer for the infinity speakers didn't think they were to expensive I will see if I can find the part numbers and prices I was quoted.
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
I'm going to assume that they are wired differently and won't be plug and play?
Trade Count:
( 0)
Threads: 41
Thanks Given: 0
0
Car: Astra J VXR
Sex: Male
Total Feedback: 0
I believe the speakers them self are plug and play just you would be missing the amp that comes as part of the infinity setup. But if I remember correctly they are a lower ohm rating than the standard speakers meaning the standard unit should still be louder
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Total Feedback: 0
But shouldn't be to hard to put the amp in tho
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Iirc they are wired differently have a look at how-to change speakers thread both diagrams are there (as links at bottom of first post).
