25:th-Jun-2014, 18:48:52
I picked up a 2005 1.6 Astra for £400 that was a non runner. Initial check over showed that 3 tyres and good clean inside and out. The main issue was the mechanical side. Once I got the battery sorted the car would just spin over, fuelling was ok so checked the HT side and found 1 spark plug in a very bad way it pulled the thread out of the head which I thought not a problem I'll helicoil it. Carried out a compression check and 0psi on all cylinders.
Stripped head of and this is what I found
![[Image: 20140625_162237_zps4ad5f018.jpg]](http://img.photobucket.com/albums/v281/cornishtaz/20140625_162237_zps4ad5f018.jpg)
![[Image: 20140625_162217_zpsb5138a2c.jpg]](http://img.photobucket.com/albums/v281/cornishtaz/20140625_162217_zpsb5138a2c.jpg)
It looks like the belt might have slipped a couple of teeth. I've never seen a piston and 3 valves completely smashed to pieces before.
I'm now trying to decide whether to drop another engine in approx £450 or strip for parts
![[Image: CameronUKAnimated.gif]](http://www.vxoc.org.uk/Images/cameron/CameronUKAnimated.gif)
