Think there's something missing??
I picked up a 2005 1.6 Astra for £400 that was a non runner. Initial check over showed that 3 tyres and good clean inside and out. The main issue was the mechanical side. Once I got the battery sorted the car would just spin over, fuelling was ok so checked the HT side and found 1 spark plug in a very bad way it pulled the thread out of the head which I thought not a problem I'll helicoil it. Carried out a compression check and 0psi on all cylinders.
Stripped head of and this is what I found
TURBO FAILURE, something else wrong
I'm in rather desperate need of ideas! Just before Xmas on a 45-mile return trip, I started to hear the turbo. It wasn't loud, but clearly there unlike normal. At Xmas, we set of on a journey with our fingers crossed, but about 35 miles down the M74, going up an uphill stretch, the turbo gave up completely. We struggled on a bit further, but were soon leaving a smoke trail, and pulled off to get recovered. The car's been in getting the turbo replaced, but the garage doing the work (they're recom
