14:th-Jul-2017, 13:58:19
Hi Guys,
Looking for some advice.
I currently drive a 1.8 Civic Type-s. Its been a good work horse for the last four years but is now showing its age as it approaches 115k on the clock.
I tend to keep my cars for around 4-5 years and do around 18K a year, so need something reliable.
Two cars have caught my eye. the first is a 2013 1.6T sri with 24k on the clock. The other is a 2.0 CDTi sport with 23K on the clock.
I'm leaning towards the 1.6T as I mainly drive b roads and when I owned a Corolla diesel I found the heavier engine made the car wallow a bit in the corners. I also had issues with it towards the end going into limp mode but not throwing any codes up. So I'm wary of diesels.
When looking at the GTC is there any common faults I should look for such as areas where paint in know to wear or rust locations (the Type-s would rust under the door seal at the corner of the window).
Any trim know to come loose?
Finally I've read on this site about the M32 gearbox and to be honest nearly decided not to touch a GTC. Is the M32 really a big issue. I read on one site that it was revised in mid 2012. Are 2013+ cars fairing any better with the gearbox?
How reliable are the turbo's?
Thanks for any and all advice
