sri suspension,
daft question, is it just the springs that are different to normal suspension, or are the dampers differant too
| Tags |
| suspension sri |
sri suspension
sri suspension,
8:th-Mar-2016, 11:42:08
Shocks are stiffer and springs are 10mm shorter
8:th-Mar-2016, 11:54:49
So if you were adding lowering springs to a normal astra would it be a good idea to use sri dampers
8:th-Mar-2016, 11:56:57
Decent springs are uprated anyway to take into account the softer shocks, it all depends on how low you want to go. If lowering by just 30mm I would say springs alone are fine.
8:th-Mar-2016, 12:43:13
(8:th-Mar-2016, 11:54:49)mrtc Wrote: So if you were adding lowering springs to a normal astra would it be a good idea to use sri dampers No I only fitted the SRI shocks as they came with the springs but I can tell you I'm going back to my soft elite springs and just keeping the sri springs. Astra-J 2.0 CDTI S/S
bad back ? or is it something to do with 19s
8:th-Mar-2016, 15:11:53
I do suffer from back problems, but it's like having no suspension at all.
8:th-Mar-2016, 19:53:51
To be fair , I didn't know they were lowered and stiffened . I thought SRi was just a trim level these days. .
I had an SRi Nova back in the day and it was obvious that it was lower , even as standard . I can't say I have noticed my SRi is lower than any other Astra despite the fact that it is difficult to crawl under. .lol
Heard there's Mod's about. .
