1:st-Jan-2016, 15:19:38
Is there any way of knowing if the car has a map on it without doing a dyno-run? Compared to my other J this one seems to be faster.
| Tags |
| map? re |
Re-map?
1:st-Jan-2016, 21:04:15
Same engines I take it? What have you been driving in between cars?
2:nd-Jan-2016, 00:38:33
Exactly the same, ive had that fiat 500 L and a couple of new corsa's. I know that I haven't had an Astra for a couple of weeks but it definitely accelerates a heck of a lot faster. My mate couldn't keep up with me where he used to be able to on the other J
2:nd-Jan-2016, 17:18:46
I was going to say maybe it's just because you've not driven it for a while but seeing as there's another factor, maybe it's been tinkered with by the previous owner. I know mine had.
2:nd-Jan-2016, 21:11:08
I'll have to dyno run it
2:nd-Jan-2016, 22:15:18
thats the only way to find out it may well be done already
you could try and contact the last owner
I've not had the v5 yet with his details, but will certainly send a letter when I get it
Sent from my iPhone using Tapatalk I've not actually sent a letter in years... Sent from my iPhone using Tapatalk
3:rd-Jan-2016, 22:02:43
You may even find them on Facebook
4:th-Jan-2016, 02:15:43
New owner of my Focus contacted me via Facebook. I found his message in the 'others' folder
4:th-Jan-2016, 15:02:15
I'll give it a go when the v5 comes through
20:th-Jan-2016, 23:35:44
@Rusty2009 my car spits out white smoke when the turbo kicks in. Not a lot but it's visible, is that a sign of a remap?
20:th-Jan-2016, 23:47:16
No mate my old zaffy did that and it hadn't be mapped
21:st-Jan-2016, 00:06:43
Hmm is it a bad thing? The white smoke I mean
21:st-Jan-2016, 00:13:54
I had it checked and was told it was fine
21:st-Jan-2016, 00:17:15
We shall see then, thanks
21:st-Jan-2016, 00:41:05
I get white smoke when first started, that normal?
21:st-Jan-2016, 14:01:34
Is it white smoke? Or steam??
Umm...
Smoke at first but goes away once warmed up a few mins. Sent from my iPhone using Tapatalk
21:st-Jan-2016, 14:31:32
If its smoke, sounds like burning oil :/ if its steam, thats normal, especially this time of year as its cold
21:st-Jan-2016, 14:40:17
Hmm may just be steam but I assumed smoke with it being a diesel.
Sent from my iPhone using Tapatalk |
