Lifting and Jacking the Vehicle (Standard)
Note: The use of a LOW PROFILE LIFT ARMS SYSTEM may be required to avoid unwanted contact with
the vehicle's body and structure depending on lifting equipment used. Refer to the manufacture's
recommendation for their applications of low profile lift arms system for their lifting equipment.
![[Image: Lifting%20and%20jacking.jpg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Tech%20data/Lifting%20and%20Jacking/Lifting%20and%20jacking.jpg)
Danger: To avoid any vehicle damage, serious personal injury or death when major components are removed from the vehicle and the vehicle is supported by a hoist, support the vehicle with jack stands at the opposite end from which the components are being removed and strap the vehicle to the hoist.
Danger: To avoid any vehicle damage, serious personal injury or death, always use the jackstands to support the vehicle when lifting the vehicle with a jack.
Caution: Perform the following steps before beginning any vehicle lifting or jacking procedure:
• Remove or secure all of the vehicle contents in order to avoid any shifting or any movement that may occur during the vehicle lifting or jacking procedure.
• The lifting equipment or the jacking equipment weight rating must meet or exceed the weight of the vehicle and any vehicle contents.
• The lifting equipment or the jacking equipment must meet the operational standards of the lifting equipment or jacking equipment manufacturer.
• Perform the vehicle lifting or jacking procedure on a clean, hard, dry, level surface.
• Perform the vehicle lifting or jacking procedure only at the identified lift points. DO NOT allow the lifting equipment or jacking equipment to contact any other vehicle components.
Failure to perform the previous steps could result in damage to the lifting equipment or the jacking equipment, the vehicle, and/or the vehicle contents.
Vehicle Lifting – Frame Contact Lift
Front Lift Pads
When lifting the vehicle with a frame-contact lift, place the front lift pads on the underbody front
side rail outrigger, as shown.
Rear Lift Pads
When lifting the vehicle with a frame-contact lift, place the rear lift pads on the rocker outer
panel weld flange, as shown.
Vehicle Jacking
Caution: When you are jacking the vehicle at the front locations, be certain that the jack or the jack lift pad does not contact the front fascia, front fascia air dam, or the front fenders. If
such contact occurs, vehicle damage may result. When jacking at selected front locations additional clearance may be required for the jacking points.
Note: When you are lifting a vehicle with a service jack, block the wheels at the opposite end from which you are lifting. Use jack stands to provide additional support.
Front of Vehicle
When using a service jack under the front of the vehicle use one of the following locations:
Place the service jack pad in the same location as shown for the front lift pads.
Rear of Vehicle
Note: Place jackstands ONLY under strong and stable vehicle structures.
Place the service jack pad in the same location as shown for the rear lift pads.
Lifting and Jacking the Vehicle (OPC Line Pack 1 and OPC)
Note: The use of a LOW PROFILE LIFT ARMS SYSTEM may be required to avoid unwanted contact with the vehicle's body and structure depending on lifting equipment used. Refer to the manufacture's recommendation for their applications of low profile lift arms system for their lifting equipment.
![[Image: Lifting%20and%20jacking%20OPC-1.jpg]](http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Tech%20data/Lifting%20and%20Jacking/Lifting%20and%20jacking%20OPC-1.jpg)
Vehicle Lifting- Frame Contact Lift
Front Lift Pads
When lifting the vehicle with a frame-contact lift, place the front lift pads on the rocker outer panel weld flange, as shown.
Rear Lift Pads
When lifting the vehicle with a frame-contact lift, place the rear lift pads on the adapter, as shown.
Vehicle Jacking
Rear Lift Pads
Vehicle Jacking
Caution: When you are jacking the vehicle at the front locations, be certain that the jack or the jack lift pad does not contact the front fascia, front fascia air dam, or the front fenders. If such contact occurs, vehicle damage may result. When jacking at selected front locations additional clearance may be required for the jacking points.
Front of Vehicle
Rear of Vehicle
Rear of Vehicle
