Jacking
So just having a look for a nice rubber pad for my trolley jack and came across this
http://www.ebay.co.uk/itm/Pinch-Weld-Tro...3ce633f2ca
I take it this allow you to jack the car up from the jacking points that you would use if using a scissor Jack?
Lifting and Jacking
Lifting and Jacking the Vehicle (Standard)
Note: The use of a LOW PROFILE LIFT ARMS SYSTEM may be required to avoid unwanted contact with
the vehicle's body and structure depending on lifting equipment used. Refer to the manufacture's
[align=center][color=#993333]recommendation for their applications of low profile lift arms system for their lifting equipment.
Jacking clips on VX Line
How do i remove these without snapping something!!?? Going crazy here![Image: http://i32.photobucket.com/albums/d38/ch...g~original]
trying to jack car to change oil
Jacking / lifting points.
Hey guys
Have a 1.7 diesel 62 plate astra J.
I am planning on jacking up the car over the weekend. Does anyone have any imagery regarding lifting points / also any tips or things to look out for when lifting this specific model car? As I know sometimes things don't run as smoothly as the manual says lol.
Any help appreciated.
Thanks again guys
