20:th-Jan-2015, 10:20:05
![[Image: 9nd4_zpsea5fce57.jpg]](http://i179.photobucket.com/albums/w301/tucpal/9nd4_zpsea5fce57.jpg)
Here is a list of the TSB's (Technical Service Bulletin's).
Please note these are in TSB's number order.
2469 2-22-11 Glued driveshaft - Missing service instruction.pdf
2473 3-19-13 Engine A-Z13DT-C-E-H-J-R - Smoke and or sizzling noise from cylinder head.pdf
2494 2-14-11 Universal Hand free Phone (UHP) - Only charging function.pdf
2495 1-21-14 Engine A17-20-DTC-H-J-L-R - Increased idle speed.pdf
2570 2-12-10 Opel Eye Switch in Steering Wheel Cruise Control Switch - Without Function.pdf
2580 7-29-11 Front seat - Noise, perceptible movement of seat cushion.pdf
2583 3-23-10 Engine Z-A17DTx, Engine Control Unit - Hang up during programming with MDI.pdf
2595 10-19-10 Radio - CD does not eject.pdf
2599 1-14-10 VIN-label - Wrong colour coding for Olympic White and Waterworld Blue.pdf
2601 2-11-10 Engine A20DTx - Delayed engine speed decrease when shifting.pdf
2604 11-22-10 Engine A-Z16-18XER - Booming Noise between 2500 - 3500 rpm.pdf
2610 11-13-12 Engine A16-18-XER-LET SVS illumates - P0597 stored.pdf
2615 5-3-10 Engine A17DTR-J - Cruise Control does not work according to specification.pdf
2621 1-10-12 Display - Flickering.pdf
2625 11-12-10 Transmission F17+ - Shift Lever Fine Adjustment.pdf
2626 4-4-12 Engine A20DTx - Glow plug with pressure sensor related failure codes.pdf
2630 5-6-10 Active headrest - Triggered.pdf
2634 3-23-10 Driver Information Centre - Code 174 displayed.pdf
2636 4-7-10 Transmission GF6 - Noise from transmission during cornering.pdf
2638 10-27-14 #14-E-2638 F40 - Knocking noise at load reversal in all gears especially in 2nd and 3rd gear.pdf
2642 4-14-10 Engine A16LET - Surge noise between 1500 and 2000 1-min.pdf
2646 5-4-10 Rear End Carrier (Flex-Fix) - Does not engage in extended position.pdf
2650 5-17-11 Cruise control, clutch apply sensor - Malfunction.pdf
2652 5-21-10 Engine - Does not start.pdf
2656 7-15-10 Inner Sill Trim, Clutch pedal - Distance too low.pdf
2664 8-2-12 Coolant level - Display shows Coolant level low.pdf
2672 12-7-11 Engine A20DTx Engine Management System - Oil Pressure too low, shut off engine appears in instrument cluster.pdf
2676 7-28-10 Instrument Panel Fuse Box - IEC Bus Bar Incorrect Numbering.pdf
2678 3-13-12 Engine Z-A17DTx - Lack of power and DPF glogged, SVS on, DTC P242F and-or P2003 might be locked.pdf
2683 4-29-11 Brake apply sensor - Brake light flickering.pdf
2684 9-7-12 Engine A20DTx - Check DPF or SVS on, DTC P2453 (5A) in ECU set..pdf
2685 9-22-11 Engine A14NEL-T - DIC message AC off due to high temp, SVS on, TC P0128 set.pdf
2686 9-1-10 Interior - Streaks on different covers.pdf
2691 9-2-10 Engine A16LET - Jerking during gear change.pdf
2696 12-7-10 UHP (Low-High-Embedded) - Phone book sorting, delay of recieved calls.pdf
2700 9-27-13 Clutch Pedal - Noisy.pdf
2714 11-8-10 Engine A17DTJ-R - Stalls during drive off.pdf
2718 11-1-11 ABS-ESP Telltale Illuminates - Several Trouble Codes are set.pdf
2723 11-24-10 Manual transmission M20-M32 and F40 - Reverse gear blocked or impossible to engage reverse gear.pdf
2724 1-10-11 Paint FRESKO BLUE - Paint deviation between Front- Rear Bumper and Body.pdf
2734 12-10-10 Engine A20DTx, Turbocharger - Loss of power, trouble code P003A, P0299 and P2263 set.pdf
2735 4-4-11 Radio CD400, CDC400 - USB Connector no Function.pdf
2745 1-19-11 Battery, beauty cover - Missing.pdf
2756 2-16-11 Rear Quater Window Panel - Design Change.pdf
2757 4-29-11 Radio DVD800 CD500 - Can not be switched on.pdf
2764 11-16-11 Heating Ventilation - Water Ingress.pdf
2769 12-14-11 Radio CD500 or DVD800 - Missing languages within config menu.pdf
2770 3-2-11 UHP - Bluetooth-PIN cannot be changed.pdf
2771 5-6-11 Pre Fuse Box (UEC) - Loose connection, P037E and or P0383(00) set.pdf
More will be added later.
![[Image: DSC03659_zpssmtodvyc.jpg]](http://i179.photobucket.com/albums/w301/tucpal/DSC03659_zpssmtodvyc.jpg)
![[Image: Tonto_zps9kmln9qb.jpg]](http://i1054.photobucket.com/albums/s497/Lewis6317/Sigs/Tonto_zps9kmln9qb.jpg)
