Requesting a Part number or technical information
Requesting a Part number or technical information.
Please be as specific as you can about the part you want, also about the technical information you require.
TSB's (Technical Service Bulletin's)
Here is a list of the TSB's (Technical Service Bulletin's).
Please note these are in TSB's number order.
2469 2-22-11 Glued driveshaft - Missing service instruction.pdf
[url=
Technical (electrical?) info needed for the DVD800 radio and HVAC control panel
I was wondering if anyone can provide me with the DVD800 Navi and the HVAC single zone control panel pinouts and perhaps an electrical wiring schematic.
As far as I can tell from searching online, the whole system consists of:
  • The actual DVD800 radio (part no. 13315944). I assume the only two round plugs are coax for the radio and GPS antennae but correct me if I'm wrong. What about the rest?
  • [url=ht
Technical Service Bulletin 3141 ECU update
Hi folks, new to the forum. I have an Astra GTC SRI 1.4 with an engine warning light issue.
My garage told me that after consulting their Technical Information Supplier with the fault codes, that it needed an ECU update in response to Technical Service Bulletin 3141.
I've just taken it into Vauxhall Wakefield and their service team have done 'an' update, but have never heard of Technical Service Bulletin 3141, so won't confirm whether or not it has fixed the warning light issue.
Does any
