connector loudspeaker adapter
Loudspeaker connector adapter
Can someone tell me will both of these two connectors work with front speakers for Opel Astra J from 2016. ?
ZRS-AG-2
ZRS-AG-21
In description for ZRS-AG-2 says it's good for all Opel models, and for ZRS-AG-21 says it's good for Opel Astra IV 2012->.
Will ZRS-AG-2 work if connector is like ZRS-AG-21, can it be used instead of ZRS-AG-21?
From the pictures of factory speakers I can see that shape of connector is like ZRS-AG-21, but I don't know if maybe ZRS-AG-2 will work.
You will the ZRS-AG-21 be warned they still need some modding to fit (found that out myself).
(20:th-May-2020, 18:13:42)Rusty2009 Wrote: You will the ZRS-AG-21 be warned they still need some modding to fit (found that out myself).
So ZRS-AG-2 will not work?
No totally the wrong connector for doors also wrong for centre dash speaker it may work on tweeters.
Here is the connector for doors 2-Way F GT 150 Series  OEM 19115644
Centre dash speaker  2-Way F 1.5-0.64 Series OEM 19115613 (U65), 19150056 (UQA), 19168545 (UQG)
Tweeter speakers  2-Way F 0.64 Series OEM 19115645 Service 13314093
Thanks for images, I couldn't find them.
I will try to use them for tweeters.
I plan to buy later rear speakers with tweeters and I will save them.
As for front speakers, I will cut off adapter and crimp spade terminals to car wires to hook them to speakers.
I read on "How to change speakers" that you couldn't solder front door speaker wires. Can you tell me what was the problem, did factory wires oxidized?
Also, is it possible to remove connector from factory speaker and solder new speaker wires onto it so that you can connect it to car connector without cutting it?
That's right the factory wiring had oxidized.
They are female terminals in the connector so hard to solder on to best off really using the adaptors or cutting
  Seat Connector Swap sheppy1 22 20,227 7:th-Feb-2015, 20:16:13
