remote issues
remote issues
hey guys
my remote has stopped working, it locks but not unlock.have changed the battery but no joy anyone had the same issue.
thanks
My Mrs Mokka is really temperamental with unlocking/locking.
You could try the negative off the battery for 60mins this will allow all systems to fully shut down & normally fixes alot of issues like this.
Thanks rusty will try
Hi rusty
tried the battery lead removal but made no difference, I have to assume it is a faulty key fob.
Have you tested it with the spare key?
hi rusty
spare key works fine
going to look into replacing the case first and if no joy the remote itself
well it was the remote case that was the issue it was an aftermarket one to begin with, got one from a scrapper damaged to use as an experiment and low and behold it works again. so i am going to have to find a better case now an original any thoughts?
Factory keys are sealed not to opened (but I'm sure it could be opened with care).
(18:th-Feb-2020, 19:30:40)Rusty2009 Wrote: Factory keys are sealed not to opened (but I'm sure it could be opened with care).
Thanks Rusty now sorted found an other factory key mint took time to undo and got it changed over works a treat
  Anyone remote SPS? milozic 1 3,131 12:th-Sep-2021, 15:31:26
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,412 12:th-Sep-2021, 15:24:05
  remote issues Qaranc 5 5,307 20:th-Oct-2020, 08:28:26
Blower issues Abc 9 9,285 14:th-Oct-2020, 13:29:13
  I bought a used GTC! - Fantastic car but a few issues i could do with advice about Mattymush 5 8,549 12:th-Jul-2020, 07:45:59
  Astra Issues – Faulty thermostat? dmort 1 6,870 15:th-Apr-2020, 12:30:52
  Astra J 2012 1.3cdti Starting Issues lordmpl 4 8,446 13:th-Jan-2019, 10:06:13
Last Post: lordmpl
  GTC Seatbelt issues Telsun 3 7,454 1:st-Jan-2019, 09:15:55
  2012 ASTRA J Central Locking Issues Matt Mcf 7 10,602 22:nd-Jan-2018, 14:05:19
  Fitted rear led lights, now bulb warning issues twinpipes 3 7,836 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
