fault codes opcom
Opcom Fault Codes
Hi everyone,
Just to give some background on why I decided to purchase an OpCom reader, I've been having the following issues on my J GTC 1.4:
  • Strange limp mode without warning lights/messages (accelerate to a certain RPM in a certain gear causes it to lose around 60% of power. It goes back to normal if I restart the car)
  • Cold start higher revs than normal - needle ticks past the 1k RPM range for a couple of minutes and then lowers to a normal rate
  • Starting the engine after a start/stop revs go up and down. The needle goes up and down for a few seconds - sometimes it almost feels like it's stalling
I've recently had it serviced which I thought may of had a positive effect but no joy.
I bought and had a play with OpCom last night. Some of the settings work but most end up "Initialising ECU" and spam my dash with all of the warnings.
When I go into Engine and choose any of the 1.4 options, nothing happens - I can't see to it to work. It just says "Initialising ECU" and does nothing.
Has anyone got it to work?
Thanks everyone.
Genuine Op-Com or Chinese knock off?
(1:st-Mar-2019, 11:47:39)Big Dave2 Wrote: Genuine Op-Com or Chinese knock off?
I'm going to presume a Chinese knock off- it's this one
When I bought my knock off one, the software was rubbish and didn't work. Someone on another forum gave me a copy of his which worked find. That was for my old Vectra-C though. It still works on my Astra-J, but when doing an auto search, it thinks it's a Vx220. Needless to say I have to input model and engine info manually.
  Option codes SomePigeon 2 3,499 31:st-Jul-2021, 19:51:14
Last Post: SomePigeon
  Hunting on Idle and Various Error Codes centurionduck 1 3,763 3:rd-Jul-2021, 17:01:32
  Astra J Fault code reader suggestions Euroshopper 1 5,119 22:nd-Feb-2021, 08:50:12
  Astra J Cutting out - no codes chesterman88 1 6,182 13:th-Dec-2018, 20:19:27
Weird electical fault JamesClark 6 8,765 2:nd-Apr-2018, 08:59:08
Last Post: vocky
  Start/Charge fault CraigSRi 2 6,500 16:th-Feb-2018, 12:01:17
Last Post: CraigSRi
  Most Bizarre Fault Ever ? GOKIWI 3 6,921 2:nd-Aug-2016, 20:55:07
Last Post: GOKIWI
  Rear Brake Light fault kyleuk2015 9 12,334 1:st-Sep-2015, 18:00:11
Last Post: kyleuk2015
  Torque APP Error codes JJ-Yorks 7 10,522 27:th-Jun-2014, 20:40:11
