to cd400 600 plus
Cd400 plus to 600
Hi everyone,
I currently have a cd400 plus with dab and usb. I have just purchased a cd 600 and would like to arrange for it to be programmed by one of the gurus if anyone is still doing that kind of work (i know im late to the game lol). Any advice who to contact? Im in the north east but will travel anywhere to get it sorted.
Thanks for any in advance for any replys.
Hi with the cd600 it would be a vci job but it also depends on your year of car as weather GM will support it.
I'm in Bournemouth and do retrofitting.
Hi mate thanks for the reply. Its a 2014 on a 64 reg. Is there a sure fire way to check as in anything on the harness or vehicle?
@Jpbroad1970 has played more with the cd600 I know it's very here in the UK.
The wiring is the same as the nav units, for ease of fitting you could do with one out of an astra. They are pretty much the same as a 950 without the nav.
Sent from my WAS-LX1A using Tapatalk
As @Rusty2009 says they are a bit rare in the uk
(18:th-Feb-2019, 08:56:41)Jpbroad1970 Wrote: The wiring is the same as the nav units, for ease of fitting you could do with one out of an astra. They are pretty much the same as a 950 without the nav.
As @rusty2009 says they are a bit rare in the uk
@Jpbroad1970 do you know from what year they where fitted was it 2014?
2014 was the earliest yeah
So the fleebay ad stated it was from an Astra so I assumed the fitment wouldn't be an issue, however in hindsight  perhaps I should have done more research. Here's a picture from the ad.
That's a navi600 mate not a cd600 easy fit they are, but you need the SD card port and the USB/AUX plus the storage tray they fit into.
Navi600 fitted and programmed is £260 (no parts supplied other than custom wiring loom).
Ah spot on mate iv got usb and aux in the vehicle already so just the sd card reader to find.
No the USB & AUX on the navi600 is all in one and the USB links into the SD port.
part number you need
13360040 SOCKET, LINE-IN AND USB £34.85
13360041 SOCKET, SD CARD £33.10
95518709 CABLE, USB, 1730MM LONG (NAVI600) (NAVI900) £14.30
13359194 STORAGE COMPARTMENT, CENTRE, LOWER, BLACK (NAVI 600, NAVI 900) £15.10
hi dan-gtc if you are unsure then get rusty to help/or do it for you ,top man he sorted my cd400 out so that i can have usb /aux/bt/dab , great chap and very helpful better then the main dealers.
3 User(s) read this thread:
orhunnx (19:th-Feb-2025, 03:24:03), Feigenbaum (4:th-Sep-2025, 13:51:15), olgacmehmet (Today, 15:41:42)
