cdti centering 2 gearstick
2.0 CDTi Gearstick Centering
Hi guys new to the forum having an issue with my astra I purchased today.
When changing gears when I go from 2nd to 3rd the stick doesn't go back to center it stays over to the left and also 6th to 4th I have to manually pull it over.
Has anyone else had this issue? When in gear the car is perfect.
While in neutral if I move stick left between 1str and 2nd the stick just stays there.
Could need some grease maybe.
(21:st-Oct-2018, 07:36:48)Rusty2009 Wrote: Could need some grease maybe.
Thank you guessing grease the turret?
Yes you could also try a gear linkage adjustment.
https://www.vxoc.org.uk/forum/Thread-How...ge-F40-Box
  1.7 CDTI - Stutters, then runs super rough, stalls and starts back up after 1h. rlievens 2 8,834 7:th-Aug-2021, 21:08:10
Last Post: Kiel0777
  2.0 CDti auto gearbox fault Big Dave2 2 3,417 1:st-Jul-2021, 13:14:50
  Glow Plugs 2.0 CDTI S/S Vx-Mad-G 9 8,356 5:th-Nov-2020, 18:43:52
  1.6 cdti Glow Plugs Loddy Jeff 4 6,054 9:th-Jul-2020, 22:09:50
Last Post: Loddy Jeff
  1.7 cdti tensioner Kingy40 0 4,046 16:th-Mar-2020, 22:27:23
Last Post: Kingy40
  1.3 cdti mk6 Poejayne 1 5,122 13:th-Mar-2019, 08:16:04
  Cambelt Interval on a 2.0 CDTI, 2011 Vx-Mad-G 6 28,245 8:th-Aug-2017, 07:49:22
Last Post: Patrunk
  GTC 2.0 cdti front pads tatters40 1 6,390 7:th-Mar-2016, 22:04:02
Last Post: irmartyn
sdfsdfsdfsdf (7:th-Jan-2025, 18:17:54)
