Gearstick Ambient Lighting
Hey All,
Does anyone need the ambient lighting module that goes around the gearstick? I'm about to have one and I won't need it so willing to sell on.
Gearstick light
Have recently got an Astra GTC. Have noticed on some pictures the red light below the gearstick. Mine does not have this. Just to see if this was standard or just on some models?
Hey
I have an ambient light here for sale which has the connector from an auto transmission Astra J. You can however snip the connector off and wire it into the ambient light circuit yourself if you have a manual car.
Anyway, pics below and part number of believe is 13306445.
Looking for £25 posted.
Cheers [Image: https://uploads.tapatalk-cdn.com/2017101...527df7.jpg][Image: https://uploads.tapatalk-cdn.com/2017101...33f462.jpg]
centre console / gearstick slider how to remove?
hi all, first time post
i placed something, quite small, on top of the slider by the gear stick, and my partner opened the slider and it slid down the back and has never returned!
Is there an easy was to gain access to this, if not easy, then any way at all to open it up?
Suggestions welcome!
Cheers!
2.0 CDTi Gearstick Centering
Hi guys new to the forum having an issue with my astra I purchased today.
When changing gears when I go from 2nd to 3rd the stick doesn't go back to center it stays over to the left and also 6th to 4th I have to manually pull it over.
Has anyone else had this issue? When in gear the car is perfect.
While in neutral if I move stick left between 1str and 2nd the stick just stays there.
