26:th-Mar-2017, 22:37:30
| heated sold interior sri |
Heated SRi interior [SOLD]
27:th-Mar-2017, 02:05:07
Willing to split the fronts only for £100
29:th-Mar-2017, 20:15:56
Only the fronts available now. £100 takes them.
6:th-Apr-2017, 17:09:48
Hi Mark
might be interested in the front seats, what connector dose the diver seat have on it,, i`m having issues finding heated seats to fit my car as a don`t seem to the the standard connector. thanks James.
7:th-Apr-2017, 17:47:17
(6:th-Apr-2017, 17:09:48)jj120979 Wrote: Hi Mark What connector are you referring to? The main plug from all Astras is the same. The only connector that is different is the pretensioner plug. They originally came with oval plugs from the facelift model. As my car is pre facelift I had to have them cut off and the pre face square plug wired on. That said I had to modify the plug on my new set so I took the plug back off and used it on my leather so these seats are ready for any plug you like on. I have the two facelift plugs I can resolder back on if needed. Sent from my iPhone using Tapatalk
7:th-Apr-2017, 22:25:19
(7:th-Apr-2017, 17:47:17)bhalay207 Wrote:(6:th-Apr-2017, 17:09:48)jj120979 Wrote: Hi Mark mark if you check hear https://www.vxoc.org.uk/forum/Thread-HOW...er-support #129 that the connector under the driver seat. Passengers has the smaller one with the orange tab.
8:th-Apr-2017, 08:19:08
They shouldn't be any different. The passenger seat from one Astra is the same as the passenger seat in another. Put a pick of your plug up and I'll compare the two but I'm confident there shouldn't be any difference.
Sent from my iPhone using Tapatalk (8:th-Apr-2017, 08:19:08)bhalay207 Wrote: They shouldn't be any different. The passenger seat from one Astra is the same as the passenger seat in another. Put a pick of your plug up and I'll compare the two but I'm confident there shouldn't be any difference. Left is body right seat
8:th-Apr-2017, 10:42:24
8:th-Apr-2017, 10:58:18
(8:th-Apr-2017, 10:42:24)bhalay207 Wrote: @rusty2009 can you shed any light on this?? Vauxhall have changed it by the looks of it. When I'm online next I'll check but TBH I've only ever seen one plug listed and it's not that one, got any other plugs? Astra-J 2.0 CDTI S/S
8:th-Apr-2017, 11:51:07
Thanks,,
the passenger side is the same as all the seats with the orange tab,, i`ve been trying for a age to find another set of seats with that type of driver side connector,, i have checked leather seats in a 15 plate Le and it have the standard plug.. im at a total loss..
17:th-Apr-2017, 10:04:31
(8:th-Apr-2017, 11:51:07)jj120979 Wrote: Thanks,, I'll be honest I'm baffled by it, I thought the plugs were all the same. Sent from my iPhone using Tapatalk
22:nd-Apr-2017, 10:02:48
may be interested in these if you still have them?, looking at adding heated seats to my sri just need to get in and make sure ive got all the pins on the seat connector
22:nd-Apr-2017, 10:04:33
22:nd-Apr-2017, 13:14:59
(22:nd-Apr-2017, 10:04:33)bhalay207 Wrote:(22:nd-Apr-2017, 10:02:48)jdkm01 Wrote: may be interested in these if you still have them?, looking at adding heated seats to my sri just need to get in and make sure ive got all the pins on the seat connector okay brilliant, ill try and have look today when I finish work is its not raining.
27:th-Apr-2017, 21:58:11
sorry for the late reply only works been a pain only got time to get in the car today. wont be able to take the seats unfortunately dont have all the pins in the passenger seat for heated seats.
5:th-May-2017, 14:44:24
(8:th-Apr-2017, 10:58:18)Rusty2009 Wrote:(8:th-Apr-2017, 10:42:24)bhalay207 Wrote: @rusty2009 can you shed any light on this?? Hi Rusty, did you manage to find anything out about my drive seat plug..?
6:th-May-2017, 07:33:46
I had a look and they only do the one plug, so i'm no wiser than you as to why you have a different plug.
9:th-May-2017, 16:17:28
(6:th-May-2017, 07:33:46)Rusty2009 Wrote: I had a look and they only do the one plug, so i'm no wiser than you as to why you have a different plug. thanks rusty been digging today and found this https://www.drive2.ru/b/1991920/ look like ill have to change the connector..
9:th-May-2017, 17:18:36
I have a spare seat connector if you need one, from a vxr which had heated seats
11:th-May-2017, 15:29:23
11:th-May-2017, 16:28:05
it's from the car body loom, not the seat loom.
11:th-May-2017, 17:59:43
dose it still have all the wiring attached?
it has all the factory pins and a section of loom attached, came from a 2016 vxr which had heated seats
30:th-May-2017, 23:08:43
I've now got my hands on a seat loom if it's any good to you?
Sent from my iPhone using Tapatalk |
![[Image: 417101.png]](http://badges.fuelly.com/images/sig-uk/417101.png)
