s progress bhalay207 thread
Bhalay207's Progress thread
#51
I did it last year in November. Today I do not see any difference despite winter road conditions.
Since then I also washed the car twice with high-presurre cleaner (from safe distance of course)
That's reassuring. In fairness, given how quick it was to do I don't mind Re doing it should I need to.
I like it
so what is it, what is plasti dip if its not paint, im confused
Rubberized Peelable Protective Coating
https://youtu.be/u8Gfd46AxLw
This arrived for me today(thanks Lewis). Luckily my postman knows the score and left it in a safe location else id have missed it. I'll get it fit later today or tomorrow.
Can anybody help with this sharkfin? I know what the cables are for... Doesn't take a genius to figure that one but I'm not sure what I need to wore the DAB wire up to.
I'm assuming the white plug is for power, the squarish plug is for FM and the circle one is for dab. It's that one which confuses me.
In the envelope I got a long VAG group cable but I can't see where I'd be using it. As it looks like it plugs into the FM cable.
I'm so confused!!
So whilst I wait for somebody marginly more switched on than me to help with the above, I thought I'd take advantage of my last day off and the nice whether and give her a little spruce
looks lovely
Those alloys are awesome mate!!! Love them!!!
Cheers guys. The wheels really set it off. I'm going to do my brake calipers soon. I'm thinking red or yellow.
Just need to do this aerial.... I keep staring at it willing an answer to come to me haha
It's like a silver version of mine! Lol
Like the wheel colour.
White plug power
Black fakra is Dab (square)
Round one is FM.
I did just send you links in the PM.
Just replied @rusty2009 ... Cheers!!
Just got it all installed, minus the FM but considering I never use that I'm not fussed. Sharkfin mod..... Complete.
Cool looks much better now
Well done mate, looks great!
Cheers guys. Strange how it can sit as it is for a short time and ad soon as you do something, no matter how small, you get the bug again!
(25:th-Feb-2016, 15:09:15)bhalay207 Wrote: Cheers guys. The wheels really set it off. I'm going to do my brake calipers soon. I'm thinking red or yellow.
Yellow or red? From my point of view black is the best choice though...
Anyway it's your choice mate.
p.s.: the car is awesome
I think i need some color along side the grey wheels
I did a tut on colour change
Ahhh.... In which case, you'll find me over there!
Just taken delivery of my new dashcam from China. It got rave reviews for the price of it, so I thought I'd replace the GS8000L that I've also just brought. Haha.
Anyway, here's the box and contents. I'm going to fit it using a dedicated hardwire kit piggybacked into the fuse box. I'll put some reviews of the camera and it's quality up later, which should be useful seeing as there's not many reviews about in general.
So ive just finished installing the camera using a hard wire kit. The build quality seems excellent for a £35 camera. One thing i didnt like is the silver ring around the lense. Seeing as I had some Plasti Dip leftover I decided to mask off the ring and spray with Plasti Dip
The finish is far from perfect but it does the job in terms of not making it so obvious that there is a camera on the window from the outside.
Good job
Well done mate, I so want a dash cam lol! Are they difficult to wire into fuse box?
This came up on my facebook today... How fast time goes!
Here's to another few years of ownership!
(14:th-Mar-2016, 16:27:19)Tonto Wrote: Well done mate, I so want a dash cam lol! Are they difficult to wire into fuse box?
No mate not at all. I piggybacked into fuse number 6 and then ran a ground cable to the existing connections just above the fuse box. Took me about an hour and a half if that.
Nice one mate, I know who to call if I get stuck haha, I'm guessing the dash cam only comes on when car is on ?
Yeah gimme a shout. I put some pictures in Sheppys how to giving another option on where to run the cable.
Fab car , where did you buy your sharkfin and how did you connecti t up ? Thanks
(14:th-Mar-2016, 21:33:44)opelastra Wrote: Fab car , where did you buy your sharkfin and how did you connecti t up ? Thanks
I brought it off a guy on here but @rusty2009 may have a link as he brought his from a website. Be warned though, they aren't cheap.
In terms of connecting it, I ran a power cable to the front accessory socket and a aerial cable to the DAB module. I've not connected the FM wire as that involves running new cabling. It's not worth it for me as I never use FM
Thanks I will buy a cheap one and see how I get on
The cheap ones suffer with signal quality apparently. I think @sheppy1 has a cheap one and he says it's ok
Yeaahh it's better than others I've had from eBay... Looks the same but does provide better signal, not perfect but not bad either I'll link to it shortly
Just been looking into plastidip, that front grille looks awesome, how easy was it compared to traditional spraying, do you have sand the surface down at all?
2012 Astra J 2.0 cdti sri
Just wipe it clean and then spray it. I'd recommend it over painting anyday!
Third.... And final dashcam has arrived. Quality looks promising. Quick drive later to see what the footage is like.
(14:th-Mar-2016, 22:36:27)bhalay207 Wrote: I've not connected the FM wire as that involves running new cabling. It's not worth it for me as I never use FM
I just taped the cable FM connector to a thin 6ft bamoo stick, making sure there were no sharp edges or anything to snag and pushed the cable between the tailgate roof lining and roof to the front passenger A pillar. I took of the front passenger hand grip off so that I could pull away the roof lining by the A pillar so that I could see the airbag, and then pulled the stick out far enough to undo the tape and pull through the FM cable. Whole job took about 15 to 20 mins in all, a lot easier than undoing the lining all the way around the passanger or drivers side, and easier than removing the trim along the floor.
Anyway, hope this dash cam does the business an it looks nice and stealthy.
Bit of an update....albeit a backwards step.
This is what's left of my passenger side led setup
I was fed up of having warning messages, fed up of flickering bulbs....generally irritated by it all. I set off checking all the wiring and ended up losing my patience and disconnecting the lot. Ive replaced it with one of my polarg bulbs but i need to get some more for the right hand side so they match as that has a error free led in it.
Oh, and to top it off i snapped one of the retaining clips on the bulb holder.
Cars!
Sent from my SM-T805 using Tapatalk
Deep intake of breath... and slooooooowly exhale.. it must have been frustrating, I think I would have also kicked the crap out of the bin to let off steam.
Haha. It was something like that yeah, especially as I was snipping it all out
Just ordered some PIAA bulbs as a replacement.
PIAA bulbs arrived, so they've been fitted and I'm now back 'old school' style.
Always hear people talking about PIAA are they just a brand and are they known to be good or something?
According to @tucpals thread they are a better fit than the polarg bulbs and apparently are abit whiter... Time will tell
Fair doos! Will pick some up if and when my halfords ones stop working
I thought you were running LEDs?
I did get some Samsung ones with my new lights but they weren't all that bright and the halfords halogen ones were brighter! Ha
Polargs on drl...
On sidelight mode...
They're a lot better than the factory bulbs (which isn't saying much) but in bright conditions you struggle to see them. Unfortunately I don't believe you can get the LED look on these type of bulbs on sunnier days, although there are probably much better bulbs than the ones I am using right now.
led will not look to good on very sunny days but it is due to the design of the drl light unit
as the bulb need to use a reflector to light the unit up
but on dull days the LED and Piaa are the best by far
Well I've noticed my Plastidip grill has suffered a blow. Dammit lol.
  Progress thread Rusty2009 Rusty2009 416 334,355 27:th-Mar-2022, 09:32:35
  Progress thread : White Astra 2.0 Cdti Sri vx line marcus 193 160,561 1:st-Aug-2021, 11:24:07
  Progress thread - AstraRT AstraRT 5 7,380 10:th-Jan-2021, 08:35:22
  Qaranc's Astra progress Qaranc 12 15,199 7:th-Nov-2020, 08:06:37
  Alex's Progress Thread AlexFitton 95 76,476 27:th-Jun-2020, 08:53:48
  Sparkyscfc74’s progress thread sparkyscfc74 485 698,426 13:th-Jun-2020, 08:24:38
  JohnL's VXR Progress thread JohnL 17 20,938 15:th-Feb-2020, 12:38:28
  Where's my thread? Telsun 2 5,919 1:st-Jan-2019, 09:49:57
  Progress Thread Conor97 Conor97 28 23,146 9:th-Sep-2018, 19:37:44
  Progress Thread: Sheppy1 sheppy1 1,759 1,249,291 30:th-Aug-2018, 09:45:17
