light fault brake rear
Rear Brake Light fault
I've got a 2011 sports tourer and my rear drivers side brake light has an error. If I remove the light and move the wires it works again. Looking to replace the wiring but it's all one unit at £56 just for that... anyone know of a common fault/fix for this? Could just change the whole light.
Are the front DRL lights ok as they can also give errors in the rear for some reason have you still got standard bulbs And what exactly does the error message say but it does sound like a faulty light cluster so changing it is most likely the best option
I would also check the DRL/Sidelights. Also when you say move the wires do you mean you give them a wiggle by the connector?
You could also try cleaning up all the contacts a bit of WD40 and sandpaper for the connector it's self use a pin or small slot head screwdriver.
Actually I had the main beam lights changed but only to Philips x-treme vision. The error just reads "check brake light". If I remove the unit and twist the light out the bulb comes on. Will take it out and give it a clean... when it decides to stop raining. Cheers.
Sent from my SM-G925F using Tapatalk
Standard error message.
(23:rd-Aug-2015, 09:12:13)kyleuk2015 Wrote: Standard error message.
There as meant to be a picture but it won't upload.
Issue is now fixed. Could this be closed please?
What was the fault? Might be useful for other users
Sent from my SM-T805 using Tapatalk
Really weird, as above I took it and moved the wire.. Bulb came on. Checked it again yesterday and moving the wire did nothing. Swapped the bulb to the indicator.. Nothing. Bulb back out and noticed the element hadn't gone but there was a slight black Mark on the metal. New bulb and fixed lol.. Feel a bit silly.
Don't feel silly mate. Main thing is that it's fixed
Cheers lol
  Lowering springs identify front rear martinpe68 1 3,990 12:th-Sep-2021, 15:22:37
  Brake pedal sensor learn. Richiew1986 0 2,945 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Astra J Fault code reader suggestions Euroshopper 1 5,219 22:nd-Feb-2021, 08:50:12
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,848 2:nd-Feb-2021, 21:12:47
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,993 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 5,140 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,759 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,929 13:th-May-2020, 14:56:05
Last Post: paula9568
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,088 25:th-Apr-2020, 07:41:05
  DPF REGEN LIGHT Starie 113 145,402 19:th-Apr-2020, 21:00:20
Last Post: Multiskilled
Users browsing this thread:
