infinity
Infinity
Does anyone know if it's possible to add infinity as the standard system isn't as good as my corsa d was so want to upgrade to infinity if possible. Any ideas?
Should be possible you would too look into the wiring etc and parts needed, although it may work out cheaper to change speakers and and install an amp.
Want to try and do it so all looks factory spec
I don't know about the speakers but the amp in the boot is plug and play so check you have the plug?!
Where would the plug be?
This is something i wondered, but couldn't find anything online about it.
IIRC it is located in the o/s rear behind the trim panel in the boot.
I can look into getting all the wiring and pin outs if you want.
^^^^ what he said
Ok I'll have to have a look thank you
So if the amp is plug and play. Are they the same speakers or do they need upgrading too
different speakers from the standard also
but check the factory sub as that is also needed
J1ODAY may show you some pictures
Can't find the cable in the boot for the life of me
there not in every car and i would have a commandant guess no of the cables will be there at all
sure rusty could work the wiring out for you but this wont be a cheap upgrade
and an after market amp would work out ££ cheaper
Don't know if it makes a difference but car is 2014 Vxr
Yeah I know it would. Just I like hidden and discreet
i am sure when rusty has the time he will look into the wiring and parts needed
very possible to do it i would look for a car that is braking that has infinity
hard to find but it would save you money if you can find the amp and sub second hand
I did get a price from the local dealer for the infinity speakers didn't think they were to expensive I will see if I can find the part numbers and prices I was quoted.
I'm going to assume that they are wired differently and won't be plug and play?
I believe the speakers them self are plug and play just you would be missing the amp that comes as part of the infinity setup. But if I remember correctly they are a lower ohm rating than the standard speakers meaning the standard unit should still be louder
But shouldn't be to hard to put the amp in tho
Iirc they are wired differently have a look at how-to change speakers thread both diagrams are there (as links at bottom of first post).
Cozzer1990 (3:rd-Mar-2024, 11:35:40), madgerald1974 (9:th-Sep-2023, 17:25:42)
