pilot park
Park pilot
Hi all
Had a quick search on here couldn't find much. Could somebody shed some light on park pilot. If I'm right in thinking it's like the ford parking system where you
Control the speed and the car scans the gap and reverses it in.??? All your help is appreciated many thanks
For all your lighting needs click below
www.lushlightingcity.co.uk
sure rusty is or has looked into this so sure he will help
You have 2 system.
1 Which is just sensors which tell you how close you are.
2 Which tells you as 1 above but you can turn it on and it will scan spaces and tell you to stop then will tell you how much to turn the wheel etc it only guides you it will not park the car for you.
I'm slowly getting all the bits to upgrade to option 2.
